one webcam works, one isnt
Posted: Sun Mar 09, 2008 6:18 pm
hi there all
this afternoon i started setting up a dedicated machine for cctv using ubuntu 7.10 server as base and zoneminder (the ubuntu package). I have 2 webcams, one basic Labtec and one Logitech STX. both have been detected out-of-the-box on my main pc which is running a standard ubuntu 7.10.
other than zoneminder the only other thing installed is webmin for server control.
i have started with the labtec camera which has been recognised and has /dev/video0- i have configured zoneminder with it and it works. than i have connected the logitech cam and it is not recognised, no /dev/video* is beeing created and the dmesg log shows:
can anyone shed any light on this?[ 18.290000] usb 5-1: new full speed USB device using ohci_hcd and address 2
[ 18.500000] usb 5-1: configuration #1 chosen from 1 choice
[ 18.780000] MC'97 1 converters and GPIO not ready (0xff00)
[ 18.780000] via82xx: Assuming DXS channels with 48k fixed sample rate.
[ 18.780000] Please try dxs_support=5 option
[ 18.780000] and report if it works on your machine.
[ 18.780000] For more details, read ALSA-Configuration.txt.
[ 18.780000] ACPI: PCI Interrupt 0000:00:11.5[C] -> Link [LNKC] -> GSI 11 (level, low) -> IRQ 11
[ 18.780000] PCI: VIA VLink IRQ fixup for 0000:00:11.5, from 255 to 11
[ 18.780000] PCI: Setting latency timer of device 0000:00:11.5 to 64
[ 18.840000] Linux video capture interface: v2.00
[ 18.880000] usbcore: registered new interface driver snd-usb-audio
[ 19.180000] /build/buildd/linux-ubuntu-modules-2.6.22-2.6.22/debian/build/build-server/media/gspcav1/gspca_core.c: USB SPCA5XX camera found.(ZC3XX)
[ 19.530000] NET: Registered protocol family 17
[ 20.310000] usb 5-1: USB disconnect, address 2
[ 20.480000] usbcore: registered new interface driver gspca
[ 20.480000] /build/buildd/linux-ubuntu-modules-2.6.22-2.6.22/debian/build/build-server/media/gspcav1/gspca_core.c: gspca driver 01.00.12 registered
[ 20.970000] loop: module loaded
[ 21.020000] lp0: using parport0 (interrupt-driven).
[ 21.480000] Adding 305192k swap on /dev/hda5. Priority:-1 extents:1 across:305192k
[ 21.800000] usb-storage: device scan complete
