Page 1 of 1
Zonet / FitiVision / Trendnet IP Cameras
Posted: Wed Mar 12, 2008 8:27 pm
by RoundSparrow
Zonet zvc7610 or zvc7610w - I figured out this with a FitiVision OEM camera. Extensive google searching landed me some useful info!
use: (snapshot)
http://x.x.x.x/cgi/jpg/image.cgi
or (motion jpeg)
http://x.x.x.x/cgi/mjpg/mjpg.cgi
source of info here:
http://www.synology.com/enu/forum/viewt ... =82&t=6849
BTW, Newegg and eWiz has these at great prices ($80) for the Ethernet units, rebate currently available too.
Some More Info?
Posted: Mon Mar 24, 2008 4:01 pm
by itsthemedication
I'm trying to get a Zonet 7610 camera to work with Zoneminder 1.22. Can you give a bit more info?
I've tried (these are entries in the source tab of the camera setup - name/path/pixels):
admin:admin@192.168.0.11
with
/cgi/mjpg/mjpg.cgi --> also tried /cgi/mjpg/mjpeg.cgi because reference page you point to says that
at
640
480
with
/cgi/jpg/image.cgi
at
640
480
No luck. I have no problem opening the connecting to the camera's setup webpage. And I don't have a clue what you mean by action=snapshot or user:(snapshot) or action=motionjp - where do these commands go? I see nothing in the documentation. Tried different resolutions as well. The system is working perfectly with 6 axis 207's, and I'm thinking I should have shelled out more money for axis, but I was trying to be a cheap bastard.
Thanks in advance...
Okay, It Works!
Posted: Fri Sep 19, 2008 4:55 pm
by itsthemedication
The zonet 7610 works with zoneminder using the following url:
admin:admin@192.168.0.xx
and source:
/cgi/jpg/image.cgi
Don't know why it wasn't happening before. But they are running! Forget about mjpeg - not going to happen on these cheap puppies. Give credit to this guy:
http://benstechcents.blogspot.com/2008/ ... eview.html
Awesome! Works on my iPhone
Posted: Mon Aug 30, 2010 4:27 am
by HankJones
I have been looking everywhere to find out if there's a way to see my Zonet ZVC7630W stream via my iPhone and nothing at all turned up. On a search on a tangent topic, I found these posts.
If I type
into my iPhone browser, it asks for the authentication credentials and then the live video begins playing!
I set up an account with dyndns.org and set up port forwarding with my router, so I can use a dyndns.org subdomain to pull up my camera from anywhere.
I wasn't successful in actually seeing any video, but apparently this works for tapping into the mpeg4 stream:
http://x.x.x.x/cgi/mpeg4/mpeg4.cgi
I would REALLY love to be able to get the stream via my wife's Motorola Cliq XT phone that runs Android but I have not had ANY luck with the browsers or the players other than getting the crappy 3gpp stream displayed using the Meridian browser. Any ideas or lessons learned are welcome.
