how to add the IP Camera to zoneminder?
hackintosh
Post by hackintosh »
hi all,
same as above topic.
for example,
now i got zoneminder server says 192.168.0.100
and i got another 2 IP camera which is 192.168.101 and 102 which is proprietary product from korea.
i see the zoneminder allow user to add the remote Camera.
I had added and set the IP but it is not working.
may i know anyone know how to add it ? or there's no such function for IP Camera ?
cordel
Post by cordel »
To add and IP camera you must know the following:
:arrow: IP of the cam.
:arrow: port to access
:arrow: path to the jpeg image or path to the script for mjpeg push
:arrow: size and palette of image being sent
All of these must be correctly set in ZM for the camera being used and different manufactures have different settings for the path.
Not all IP cameras work with ZM. If it's on our HCL in the wiki, then it should be able to work.
