Overwrite files settings :-(
paoloplex
Post by paoloplex »
Hi everybody, I ask you some help regarding settings in ZM.
How and where do you set the overwrite regarding the disk? When the disk is full i will automatcly overwrite new files on the oldiest. Is it possible?
Is it possible to set a limitation on the disk, for example 80 Gb? Where is it possible to set it?
Thanks in advance, Paolo.
cordel
Post by cordel »
