When I try to configure 1.23.2 I get this error and I'm not sure what it is looking for.
"configure: error: zm requires PHP::Serialization"
This is on a fedora 8 box.
Here the configure options I'm using
./configure --with-webdir=/var/www/html/zm --with-cgidir=/var/wwwcgi-bin ZM_DB_HOST=loclhost ZM_DB_NAME=video ZM_DB_USER=video ZM_DB_PASS=MyPAssWordHere ZM_SSL_LIB=openssl CFLAGS="-g -O3 -march=pentium4" CXXFLAGS="-g -O3 -march=pentium4"
Configure error
- zoneminder
- Site Admin
- Contact:
It is possible that that module is not available via yum in which case you will have to do it manually. Just type If it is your first time it will ask if you want to configure it. Say 'y' if you want to answer a bunch of questions or 'n' (easier) to just accepts defaults. Then type and then when it has finished to exit.
perl -MCPAN -eshell
install PHP::Serialization
quit
Phil
Hey thanks, I tried to install the RPM and it did not work. When I type the first line I get the complaint
"perl -MCPAN -eshell
Can't locate CPAN.pm in @INC (@INC contains: /usr/lib/perl5/site_perl/5.8.8/i386-linux-thread-multi /usr/lib/perl5/site_perl/5.8.7/i386-linux-thread-multi /usr/lib/perl5/site_perl/5.8.6/i386-linux-thread-multi /usr/lib/perl5/site_perl/5.8.5/i386-linux-thread-multi /usr/lib/perl5/site_perl/5.8.8 /usr/lib/perl5/site_perl/5.8.7 /usr/lib/perl5/site_perl/5.8.6 /usr/lib/perl5/site_perl/5.8.5 /usr/lib/perl5/site_perl /usr/lib/perl5/vendor_perl/5.8.8/i386-linux-thread-multi /usr/lib/perl5/vendor_perl/5.8.7/i386-linux-thread-multi /usr/lib/perl5/vendor_perl/5.8.6/i386-linux-thread-multi /usr/lib/perl5/vendor_perl/5.8.5/i386-linux-thread-multi /usr/lib/perl5/vendor_perl/5.8.8 /usr/lib/perl5/vendor_perl/5.8.7 /usr/lib/perl5/vendor_perl/5.8.6 /usr/lib/perl5/vendor_perl/5.8.5 /usr/lib/perl5/vendor_perl /usr/lib/perl5/5.8.8/i386-linux-thread-multi /usr/lib/perl5/5.8.8 .).
BEGIN failed--compilation aborted."
Any idea what I'm missing in perl?
zoneminder wrote:It is possible that that module is not available via yum in which case you will have to do it manually. Just typeIf it is your first time it will ask if you want to configure it. Say 'y' if you want to answer a bunch of questions or 'n' (easier) to just accepts defaults. Then typeCode: Select all
perl -MCPAN -eshell
and then when it has finishedCode: Select all
to exit.Code: Select all
quit
