missing zmcontrol-axis-v2.pl script
vizo
Post by vizo »
So I finally got zoneminder to work with a wvc200 using ffserver. Next I want to get pt working. According this post http://www.zoneminder.com/forums/viewto ... ght=wvc200 I should be able to accomplish this by modifying the zmcontrol-axis-v2.pl script.
I do not seem to be able to find this script. Can anyone point in the right direction in finding it?
Much thanks
-vizo-
cordel
Post by cordel »
Run the following:
whereis AxisV2
Controls scripts have now been made into perl modules as of 1.23.0, so they will be installed in with your other perl modules. The Path may vary a bit depending on the distro hence the search.
vizo
Post by vizo »
Got it.
Thanks!!
merlin
Post by merlin »
As you have worked it out how to use wvc200, maxbe you can post what you have done ?
