Card not recognized by kernel
Hi @ all,
im a new user, after several weeks and retries i have finally installed zm under ubuntu 7.10 with success, but i have a problem with it; i have a digitalprotect pci capture card with 16 inputs (2 serial ports).
My problem is i can only see bluescreens with date and camname.
how can i solv it?
thx @all
how can i solv it?
thx @all
Hi, i have this card http://security-center.de/de/espkat/docs/tv8807.pdf
is a german site, 100 pic/s
the philips usb webcam is now streaming, i have just switched to yuv420p
/dev/video0
the other cam which is plugged on the tv8807 is still strickin
dmesg |grep bttv shows an ...UNKOWN/GENERIC...
under windows xp depend nanobt 8 drivers (4 for audio and 4 for video) !!!
ls -v schows 02:0e.0 Multimedia video controller: Brootree Corporation BT878 Video Capture (rev 11) ...capabilities: <access>...
thx
thx
If I understand well your card is a TV8807 (the link you provide doesn't show any card).
And you haven't said how your inputs are configures in zone minder.
I'm not sure, but your inputs probably have to be setup this way:
Input 01 - /dev/video0(0)
Input 02 - /dev/video0(1)
Input 03 - /dev/video0(2)
Input 04 - /dev/video0(3)
Input 05 - /dev/video1(0)
Input 06 - /dev/video1(1)
Input 07 - /dev/video1(2)
Input 08 - /dev/video1(3)
Input 09 - /dev/video2(0)
Input 10 - /dev/video2(1)
Input 11 - /dev/video2(2)
Input 12 - /dev/video2(3)
Input 13 - /dev/video3(0)
Input 14 - /dev/video3(1)
Input 15 - /dev/video3(2)
Input 16 - /dev/video3(3)
If you're not sure your camera is working well, you can use a DVD/VHS composite output (Yellow RCA connector) as video feed.
Best regards.
Best regards.
hi, i have updated the link, is a pdf datasheet.
ubuntu detects the usb webcam on /dev/video0
from the card 4 inputs:
/dev/video1 i have here pluged a visortech cam model: an380mc
/dev/video2
/dev/video3
/dev/video4
the video feed is working well (on a tv via the composite output from the card) but in zyklus mode but not on zm!!
THX
/dev/video2
/dev/video3
/dev/video4
THX
i have defined 5 monitors;cordel wrote:Most likely each chip has four inputs/channles (0 to 3), have you defined these?
Would be like caladeira posted above. Your last post would suggest you overlooked them.
philips monitor /dev/video0 (0) <--- philips webcam plugged work
input01 digiprotect1 monitor /dev/video1(0) <--visor cam plugged bluescreen
input02 digiprotect2 monitor /dev/video1(1) <---no cam bluescreen
input03 digiprotect3 monitor /dev/video1(2) <---no cam bluescreen
input04 digiprotect4 monitor /dev/video1(3) <---no cam bluescreen
THX
//edit:
the tail -f... command shows:
.......[Can´t find process with command of 'zma -m17']
tehre are 4x chips on the card: conexant fusion 878a 25878-13 0545y1fx
and a PLX chip: pci6140-aa33pc a0527a
and an atmel 0530 at89c2051-24pi
Are you sure you have the cam on /dev/video1 chip and not on one of the others?
Are you sure that the card has been detected and setup by the kernel correctly.
Might have a go at going through some of the trouble shooting documentation, this way you can give us better information
http://www.zoneminder.com/forums/viewtopic.php?t=10820
http://www.zoneminder.com/wiki/index.php/FAQ
i have tested all of the 16 inputs and every chanel with different video settings and mods!!cordel wrote:Are you sure you have the cam on /dev/video1 chip and not on one of the others?
dmesg |grep bttv shows an ...UNKOWN/GENERIC...cordel wrote:Are you sure that the card has been detected and setup by the kernel correctly.
...capabilities: access denied ...
i had a go throgh the FAQ and trouble shooting threads
I'm not personally familiar with that card, the fact you get a blue screen is a good sign but not a guarantee that it might work. The card does have to have the correct drivers loaded so ZM can control it. With any luck maybe some one that has this card working will happen along and give a clue as to the card type.
Otherwise I think lspci -vv and google might be your best bet and allot of toying around.
You could also search through:
http://www.bttv-gallery.de/high/index.html
and see if anything turns up there.
I do't suggest just looking through that page as there are alot of cards listed on that page, lspci should turnup something usefull.
morning @ all, its me again,
my displays are stil blue, i have some logs for you, help me plz
an other branding for the card!!
http://vangold.en.alibaba.com/product/5 ... _Card.html
http://vangold.en.alibaba.com/product/5 ... l?index=30
Many THX
//edit:
@ cordel here is the hole lspci -vv, i have edited my post in this thread
spock@ZmBox:~$ sudo zmu -d/dev/video0 -q -v
Video Capabilities
Name: BT878 video ( *** UNKNOWN/GENER
Type: 171
Can capture
Can tune
Overlay onto frame buffer
Can clip
Scalable
Video Channels: 4
Audio Channels: 1
Maximum Width: 640
Maximum Height: 576
Minimum Width: 48
Minimum Height: 32
Window Attributes
X Offset: 0
Y Offset: 0
Width: 320
Height: 240
Picture Attributes
Palette: 4 - 24bit RGB
Colour Depth: 24
Brightness: 32768
Hue: 32768
Colour :32768
Contrast: 32768
Whiteness: 0
Channel 0 Attributes
Channel: 0
Flags: 3
Channel has a tuner
Channel has audio
Type: 1 - TV
Format: 3 - AUTO
Channel 1 Attributes
Channel: 1
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 3 - AUTO
Channel 2 Attributes
Channel: 2
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 3 - AUTO
Channel 3 Attributes
Channel: 3
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 3 - AUTO
spock@ZmBox:~$ dmesg | grep bttv
[ 37.058201] bttv: driver version 0.9.17 loaded
[ 37.058213] bttv: using 8 buffers with 2080k (520 pages) each for capture
[ 37.058365] bttv: Bt8xx card found (0).
[ 37.058455] bttv0: Bt878 (rev 17) at 0000:02:0c.0, irq: 11, latency: 64, mmio: 0xcdbfe000
[ 37.058472] bttv0: using: *** UNKNOWN/GENERIC *** [card=0,autodetected]
[ 37.058539] bttv0: gpio: en=00000000, out=00000000 in=003fffff [init]
[ 38.358419] bttv0: using tuner=-1
[ 38.358425] bttv0: i2c: checking for MSP34xx @ 0x80... <6>input: PS/2 Generic Mouse as /class/input/input3
[ 38.582719] bttv0: i2c: checking for TDA9875 @ 0xb0... found
[ 38.622446] bttv0: i2c: checking for TDA7432 @ 0x8a... not found
[ 38.622961] bttv0: i2c: checking for TDA9887 @ 0x86... found
[ 38.623644] bttv0: registered device video0
[ 38.623720] bttv0: registered device vbi0
[ 38.623803] bttv: Bt8xx card found (1).
[ 38.623891] bttv1: Bt878 (rev 17) at 0000:02:0d.0, irq: 5, latency: 64, mmio: 0xcdbfc000
[ 38.623910] bttv1: using: *** UNKNOWN/GENERIC *** [card=0,autodetected]
[ 38.623963] bttv1: gpio: en=00000000, out=00000000 in=007fffff [init]
[ 39.419591] bttv1: using tuner=-1
[ 39.419787] bttv1: registered device video1
[ 39.419845] bttv1: registered device vbi1
[ 39.419915] bttv: Bt8xx card found (2).
[ 39.419990] bttv2: Bt878 (rev 17) at 0000:02:0e.0, irq: 5, latency: 64, mmio: 0xcdbfa000
[ 39.420020] bttv2: using: *** UNKNOWN/GENERIC *** [card=0,autodetected]
[ 39.420071] bttv2: gpio: en=00000000, out=00000000 in=00bf7fff [init]
[ 40.218901] bttv2: using tuner=-1
[ 40.219520] bttv2: registered device video2
[ 40.219808] bttv2: registered device vbi2
[ 40.311132] bttv: Bt8xx card found (3).
[ 40.311232] bttv3: Bt878 (rev 17) at 0000:02:0f.0, irq: 11, latency: 64, mmio: 0xcdbf8000
[ 40.311257] bttv3: using: *** UNKNOWN/GENERIC *** [card=0,autodetected]
[ 40.311319] bttv3: gpio: en=00000000, out=00000000 in=00ffffff [init]
[ 41.110135] bttv3: using tuner=-1
[ 41.110932] bttv3: registered device video3
[ 41.111251] bttv3: registered device vbi3
spock@ZmBox:~$ xawtv -hwscan
[: 12: (opcode:: unexpected operator
This is xawtv-3.95.dfsg.1, running on Linux/i686 (2.6.22-14-generic)
looking for available devices
port 306-337
type : Xvideo, image scaler
name : NV05 Video Blitter
/dev/video0: OK [ -device /dev/video0 ]
type : v4l2
name : BT878 video ( *** UNKNOWN/GENER
flags: overlay capture tuner
/dev/video1: OK [ -device /dev/video1 ]
type : v4l2
/dev/video2: OK [ -device /dev/video2 ]
type : v4l2
/dev/video3: OK [ -device /dev/video3 ]
type : v4l2
spock@ZmBox:~$ lspci -vv
----------SNIP---------------
02:0c.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B-
Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort>SERR- <PERR-
Latency: 64 (4000ns min, 10000ns max)
Interrupt: pin A routed to IRQ 11
Region 0: Memory at cdbfe000 (32-bit, prefetchable) [size=4K]
Capabilities: <access>
02:0c.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
Control: I/O- Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B-
Region 0: Memory at cdbff000 (32-bit, prefetchable) [size=4K]
02:0d.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
Interrupt: pin A routed to IRQ 5
Region 0: Memory at cdbfc000 (32-bit, prefetchable) [size=4K]
02:0d.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
Region 0: Memory at cdbfd000 (32-bit, prefetchable) [size=4K]
02:0e.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
Region 0: Memory at cdbfa000 (32-bit, prefetchable) [size=4K]
02:0e.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
Region 0: Memory at cdbfb000 (32-bit, prefetchable) [size=4K]
02:0f.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
Region 0: Memory at cdbf8000 (32-bit, prefetchable) [size=4K]
02:0f.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
Region 0: Memory at cdbf9000 (32-bit, prefetchable) [size=4K]
Many THX
//edit:
If you run and post a snip of the results for the capture card of lspci -vvcordel wrote:I'm not personally familiar with that card, the fact you get a blue screen is a good sign but not a guarantee that it might work. The card does have to have the correct drivers loaded so ZM can control it. With any luck maybe some one that has this card working will happen along and give a clue as to the card type.
some one might be able to help, otherwise we are guessing like you are.
Also moved this to it's own topic as it is rude to hijack someone elses thread.
Thanks,
Corey
hi Cordel i have pastetd the hole lspci -vv log above, could you plz take a look?cordel wrote:
Thanks,
Corey
nevermind,
here is the scanpci -v log, im a newbie in linux, help me plz
many thx
spock@ZmBox:~$ sudo scanpci -v
[sudo] password for spock:
pci bus 0x0000 cardnum 0x00 function 0x00: vendor 0x1039 device 0x0735
Silicon Integrated Systems [SiS] 735 Host
STATUS 0x2210 COMMAND 0x0007
CLASS 0x06 0x00 0x00 REVISION 0x01
BIST 0x00 HEADER 0x80 LATENCY 0x20 CACHE 0x00
BASE0 0xd0000000 addr 0xd0000000 MEM
pci bus 0x0000 cardnum 0x01 function 0x00: vendor 0x1039 device 0x0001
Silicon Integrated Systems [SiS] Virtual PCI-to-PCI bridge (AGP)
STATUS 0x0000 COMMAND 0x0107
CLASS 0x06 0x04 0x00 REVISION 0x00
HEADER 0x01 LATENCY 0x40
PRIBUS 0x00 SECBUS 0x01 SUBBUS 0x01
SECLT 0x40 SECSTATUS 0x2000
IOBASE 0xf000 IOLIM 0x0fff
NOPREFETCH_MEMBASE 0xcdd00000 MEMLIM 0xcfdfffff
PREFETCH_MEMBASE 0xbd900000 MEMLIM 0xcdafffff
NO_FAST_B2B NO_SEC_BUS_RST NO_M_ABRT VGA_EN NO_ISA_EN SERR_EN NO_PERR_EN
pci bus 0x0000 cardnum 0x02 function 0x00: vendor 0x1039 device 0x0018
Silicon Integrated Systems [SiS] SiS85C503/5513 (LPC Bridge)
STATUS 0x0200 COMMAND 0x000f
CLASS 0x06 0x01 0x00 REVISION 0x00
BIST 0x00 HEADER 0x80 LATENCY 0x00 CACHE 0x00
BYTE_0 0xd8 BYTE_1 0x0b BYTE_2 0x0b BYTE_3 0x0a
pci bus 0x0000 cardnum 0x02 function 0x01: vendor 0x1039 device 0x0016
Silicon Integrated Systems [SiS] SiS961/2 SMBus Controller
STATUS 0x0200 COMMAND 0x0001
CLASS 0x0c 0x05 0x00 REVISION 0x00
BIST 0x00 HEADER 0x00 LATENCY 0x00 CACHE 0x00
BASE4 0x00000c01 addr 0x00000c00 I/O
MAX_LAT 0x00 MIN_GNT 0x00 INT_PIN 0x02 INT_LINE 0x00
BYTE_0 0x01 BYTE_1 0x00 BYTE_2 0x00 BYTE_3 0x00
pci bus 0x0000 cardnum 0x02 function 0x02: vendor 0x1039 device 0x7001
Silicon Integrated Systems [SiS] USB 1.0 Controller
STATUS 0x0280 COMMAND 0x0117
CLASS 0x0c 0x03 0x10 REVISION 0x07
BIST 0x00 HEADER 0x00 LATENCY 0x40 CACHE 0x08
BASE0 0xcfffe000 addr 0xcfffe000 MEM
MAX_LAT 0x50 MIN_GNT 0x00 INT_PIN 0x04 INT_LINE 0x05
pci bus 0x0000 cardnum 0x02 function 0x03: vendor 0x1039 device 0x7001
BASE0 0xcffff000 addr 0xcffff000 MEM
MAX_LAT 0x50 MIN_GNT 0x00 INT_PIN 0x01 INT_LINE 0x0a
pci bus 0x0000 cardnum 0x02 function 0x05: vendor 0x1039 device 0x5513
Silicon Integrated Systems [SiS] 5513 [IDE]
STATUS 0x0000 COMMAND 0x0005
CLASS 0x01 0x01 0x80 REVISION 0xd0
BIST 0x00 HEADER 0x80 LATENCY 0x80 CACHE 0x00
BASE4 0x0000ff01 addr 0x0000ff00 I/O
BYTE_0 0x31 BYTE_1 0x81 BYTE_2 0x00 BYTE_3 0x00
pci bus 0x0000 cardnum 0x0b function 0x00: vendor 0x3388 device 0x0021
Hint Corp HB6 Universal PCI-PCI bridge (non-transparent mode)
STATUS 0x0290 COMMAND 0x0106
CLASS 0x06 0x04 0x00 REVISION 0x11
PRIBUS 0x00 SECBUS 0x02 SUBBUS 0x02
SECLT 0x40 SECSTATUS 0x2280
NOPREFETCH_MEMBASE 0xcfe00000 MEMLIM 0xcfefffff
PREFETCH_MEMBASE 0xcdb00000 MEMLIM 0xcdbfffff
NO_FAST_B2B NO_SEC_BUS_RST NO_M_ABRT NO_VGA_EN NO_ISA_EN SERR_EN PERR_EN
pci bus 0x0000 cardnum 0x0f function 0x00: vendor 0x10ec device 0x8139
Realtek Semiconductor Co., Ltd. RTL-8139/8139C/8139C+
STATUS 0x0280 COMMAND 0x0107
CLASS 0x02 0x00 0x00 REVISION 0x10
BIST 0x00 HEADER 0x00 LATENCY 0x40 CACHE 0x00
BASE0 0x0000dc01 addr 0x0000dc00 I/O
BASE1 0xcfffdf00 addr 0xcfffdf00 MEM
MAX_LAT 0x40 MIN_GNT 0x20 INT_PIN 0x01 INT_LINE 0x05
pci bus 0x0000 cardnum 0x13 function 0x00: vendor 0x1106 device 0x3038
VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller
CardVendor 0x0925 card 0x1234 (VIA Technologies, Inc. (Wrong ID) USB Controller)
STATUS 0x0210 COMMAND 0x0017
CLASS 0x0c 0x03 0x00 REVISION 0x50
BIST 0x00 HEADER 0x80 LATENCY 0x40 CACHE 0x08
BASE4 0x0000d401 addr 0x0000d400 I/O
MAX_LAT 0x00 MIN_GNT 0x00 INT_PIN 0x01 INT_LINE 0x0b
BYTE_0 0x40 BYTE_1 0x12 BYTE_2 0x03 BYTE_3 0x00
pci bus 0x0000 cardnum 0x13 function 0x01: vendor 0x1106 device 0x3038
BASE4 0x0000d801 addr 0x0000d800 I/O
MAX_LAT 0x00 MIN_GNT 0x00 INT_PIN 0x02 INT_LINE 0x0b
pci bus 0x0000 cardnum 0x13 function 0x02: vendor 0x1106 device 0x3104
VIA Technologies, Inc. USB 2.0
CardVendor 0x0925 card 0x1234 (VIA Technologies, Inc. (Wrong ID), Card unknown)
CLASS 0x0c 0x03 0x20 REVISION 0x51
BIST 0x00 HEADER 0x80 LATENCY 0x40 CACHE 0x10
BASE0 0xcfffde00 addr 0xcfffde00 MEM
MAX_LAT 0x00 MIN_GNT 0x00 INT_PIN 0x03 INT_LINE 0x0a
BYTE_0 0x00 BYTE_1 0x02 BYTE_2 0x01 BYTE_3 0x00
pci bus 0x0001 cardnum 0x00 function 0x00: vendor 0x10de device 0x0201
nVidia Corporation NV20 [GeForce3 Ti 200]
CardVendor 0x1462 card 0x5113 (Micro-Star International Co., Ltd., Card unknown)
STATUS 0x02b0 COMMAND 0x0007
CLASS 0x03 0x00 0x00 REVISION 0xa3
BIST 0x00 HEADER 0x00 LATENCY 0xf8 CACHE 0x00
BASE0 0xce000000 addr 0xce000000 MEM
BASE1 0xc0000008 addr 0xc0000000 MEM PREFETCHABLE
BASE2 0xcda80008 addr 0xcda80000 MEM PREFETCHABLE
MAX_LAT 0x01 MIN_GNT 0x05 INT_PIN 0x01 INT_LINE 0x0b
BYTE_0 0x62 BYTE_1 0x14 BYTE_2 0x13 BYTE_3 0x51
pci bus 0x0002 cardnum 0x0c function 0x00: vendor 0x109e device 0x036e
CLASS 0x04 0x00 0x00 REVISION 0x11
BIST 0x00 HEADER 0x80 LATENCY 0x40 CACHE 0x00
BASE0 0xcdbfe008 addr 0xcdbfe000 MEM PREFETCHABLE
MAX_LAT 0x28 MIN_GNT 0x10 INT_PIN 0x01 INT_LINE 0x0b
pci bus 0x0002 cardnum 0x0c function 0x01: vendor 0x109e device 0x0878
STATUS 0x0290 COMMAND 0x0102
CLASS 0x04 0x80 0x00 REVISION 0x11
BASE0 0xcdbff008 addr 0xcdbff000 MEM PREFETCHABLE
MAX_LAT 0xff MIN_GNT 0x04 INT_PIN 0x01 INT_LINE 0x0b
pci bus 0x0002 cardnum 0x0d function 0x00: vendor 0x109e device 0x036e
BASE0 0xcdbfc008 addr 0xcdbfc000 MEM PREFETCHABLE
MAX_LAT 0x28 MIN_GNT 0x10 INT_PIN 0x01 INT_LINE 0x0a
pci bus 0x0002 cardnum 0x0d function 0x01: vendor 0x109e device 0x0878
BASE0 0xcdbfd008 addr 0xcdbfd000 MEM PREFETCHABLE
MAX_LAT 0xff MIN_GNT 0x04 INT_PIN 0x01 INT_LINE 0x0a
pci bus 0x0002 cardnum 0x0e function 0x00: vendor 0x109e device 0x036e
BASE0 0xcdbfa008 addr 0xcdbfa000 MEM PREFETCHABLE
MAX_LAT 0x28 MIN_GNT 0x10 INT_PIN 0x01 INT_LINE 0x05
pci bus 0x0002 cardnum 0x0e function 0x01: vendor 0x109e device 0x0878
BASE0 0xcdbfb008 addr 0xcdbfb000 MEM PREFETCHABLE
MAX_LAT 0xff MIN_GNT 0x04 INT_PIN 0x01 INT_LINE 0x05
pci bus 0x0002 cardnum 0x0f function 0x00: vendor 0x109e device 0x036e
BASE0 0xcdbf8008 addr 0xcdbf8000 MEM PREFETCHABLE
pci bus 0x0002 cardnum 0x0f function 0x01: vendor 0x109e device 0x0878
BASE0 0xcdbf9008 addr 0xcdbf9000 MEM PREFETCHABLE
pci bus 0x00ad cardnum 0x11 function 0x00: vendor 0xffff device 0xffff
Device unknown
STATUS 0xffff COMMAND 0xffff
CLASS 0xff 0xff 0xff REVISION 0xff
BIST 0xff HEADER 0x00 LATENCY 0xff CACHE 0xff
BASE0 0xffffffff addr 0xfffffffc I/O
BASE1 0xffffffff addr 0xfffffffc I/O
BASE2 0xffffffff addr 0xfffffffc I/O
BASE3 0xffffffff addr 0xfffffffc I/O
BASE4 0xffffffff addr 0xfffffffc I/O
BASE5 0xffffffff addr 0xfffffffc I/O
BASEROM 0xffffffff addr 0xffff8000 decode-enabled
MAX_LAT 0xff MIN_GNT 0xff INT_PIN 0xff INT_LINE 0xff
BYTE_0 0xff BYTE_1 0xff BYTE_2 0xff BYTE_3 0xff
spock@ZmBox:~$ cat /proc/interrupts
CPU0
0: 82503 XT-PIC-XT timer
1: 154 XT-PIC-XT i8042
2: 0 XT-PIC-XT cascade
5: 22908 XT-PIC-XT ohci_hcd:usb1, eth0, bttv2
6: 3 XT-PIC-XT floppy
7: 0 XT-PIC-XT parport0
8: 3 XT-PIC-XT rtc
9: 1 XT-PIC-XT acpi
10: 23001 XT-PIC-XT ohci_hcd:usb2, ehci_hcd:usb5, bttv1
11: 66695 XT-PIC-XT uhci_hcd:usb3, uhci_hcd:usb4, bttv0, bttv3, nvidia
12: 1427 XT-PIC-XT i8042
14: 75414 XT-PIC-XT libata
15: 4010 XT-PIC-XT libata
NMI: 0
LOC: 0
ERR: 0
MIS: 0
