Could you confirm me please if the ZoneMinder software is compatible with all axis camera?
Thanks in advance,
Axis Communications
Florian Combacau
Tel : 01 49 69 61 93
Axis Camera Compatibility
Yes most cams are compatable but not all. See the HCL in the Wiki.http://www.zoneminder.com/wiki/index.ph ... d_hardware
ZM Does not support MPEG streams and the 2100 has issues.
Mjpeg push is obviouly prefered
Regards,
Corey
Regards,
Corey
- zoneminder
- Site Admin
- Contact:
AFAIK Mpeg support is being funded by donation.... expect about 2010 lol
only kidding
No its not related to V4L2 as that is for capture cards not ip cams. Phil is as always putting the hours in to put this support in
only kidding
James Wilson
- Contact:
Sounds good to me, but there's one question left -
is there any possibility for zoneminder to stream data from axis cams through https/ssl connection instead of http?
The Axis 210A is capable of serving pictures through https and I would need that feature (don't ask why, it's a university with very concerned people), because it won't be in a private subnet.
Thanks in advance for some hints about that...
best regards,
robert
best regards,
robert
