loss of signal alarm with remote camera
Posted: Fri Mar 28, 2008 6:28 pm
I am using the following
ubuntu 7.10
alix 3c2
Logitech quickcam communicate deluxe
uvcvideo driver (latest from their version control)
mjpg_stream
zoneminder from apt-get with universe/multiverse on
I have zm set to 3 fps, and mjpg_stream I have tried from 3 to 10 fps, and I geep getting alarms of "signal" which I assume are loss of signal alarms, but according to the documentation those should not be generated if you are using a remote cam. I tried checking the box in options where it asks if you will be using networked cameras and that did not stop the loss of signal alarms. libjpeg was failing a couple of places when zm was trying to put the timestamp on the images so I coded around that to see if it helps. I am still getting loss of signal alarms (about 3 a minute) which is making my event list huge. Is it possible that if there is some type of error processing the image that it is assumed to be due to a loss of signal event, and the fact that it is a networked cam is missed? If not, is there any way to completely disable any and all loss of signal alarms?
Thanks in advance for any help.
ubuntu 7.10
alix 3c2
mjpg_stream
