Can't delete events files
bigmonk
Post by bigmonk »
I had a power flicker which caused an unclean reboot and some database corruption. I got the database corruption problem fixed but there are large files in my events folder that I can't delete. When I try to remove them by rm -rf ..../events/* the computer just hangs.
I apparently have too many files in this folder. How can I delete these files?
Running Fedora 8.
ernesto
Post by ernesto »
find . -name '*.*' | xargs rm
sfmartin
Post by sfmartin »
The rm command usually takes a while to process when you want to delete a folder that contains a huge qty of files. I had the same situation in the past. I just ran the command and left the PC working during the night. After several minutes (maybe hours), it completed the deletion of the folder.
Regards,
Sebastian
Lee Sharp
Post by Lee Sharp »
Look at top. It probably shows "rm" as the highest process merrily chugging along deleting a large file or directory.
nabetse_x
Post by nabetse_x »
find -type f | grep \.jpg | xargs rm
i use that command and works nice...
yo uso ese comando y funciona muy bien...
