hi all,
is it possible to integrate the video server to zoneminder ??
as i know the IP camera can be done , right ?
thanks 1st
is it possible to add the video server to zoneminder
http://www.axis.com/products/cam_2400/ <== like this product, some ppl called it as Network Video Server.kylejohnson wrote:What do you mean by "the video server"?
Yes - IP cameras can be added.
IP Camera <==for IP camera, if my camera is not listed in /usr/lib/perl5/site_perl/5.8.8/ZoneMinder/Control
, is it my camera is not able to integrate into zonemindeR??????????
The Perl modules for control are spacificaly for PTZ control.
It would be much simpler if you just tell us what cam you have and ask if it works, but we also have an HCL on the wiki and you can probably find the same information by searching the forum for your hardware much quicker.
