I am running 1.22.3
I have a PWF filter setup to run in background, when disk percent greater than 50, sort by ID ASC, limit to first 1000 records, delete all matches.
It doesn't work automatically.
If I 'execute' the filter manually, it brings up 1000 records, but I then have to select all and delete'.
I tried creating 'PurgeWhenFull2' and thats doesn't appear to work.
Obviously, the system works, so I must be doing something wrong but I can't work it out for the life of me.
Whilst I am here, whats the difference between submit and execute on the filter window?
Thanks for your help.
Another PurgeWhenFull problem.
Thanks for the replies guys.
Thanks to you we are a little closer!
My zmfilter.log remains empty but zmdc.log states:
[root@localhost zm]# tail zmdc.log
04/18/08 19:22:03.861544 zmdc[17563].ERR ['zmfilter.pl ' exited abnormally, exit status 9]
04/18/08 19:22:23.068290 zmdc[17563].INF [Starting pending process, zmfilter.pl]
04/18/08 19:22:23.073455 zmdc[17563].INF ['zmfilter.pl' starting at 08/04/18 19:22:23, pid = 17649]
04/18/08 19:22:23.892201 zmdc[17563].ERR ['zmfilter.pl ' exited abnormally, exit status 9]
04/18/08 19:23:03.000751 zmdc[17563].INF [Starting pending process, zmfilter.pl]
04/18/08 19:23:03.003099 zmdc[17563].INF ['zmfilter.pl' starting at 08/04/18 19:23:03, pid = 17678]
04/18/08 19:23:03.998612 zmdc[17563].ERR ['zmfilter.pl ' exited abnormally, exit status 9]
04/18/08 19:24:23.003667 zmdc[17563].INF [Starting pending process, zmfilter.pl]
04/18/08 19:24:23.012996 zmdc[17563].INF ['zmfilter.pl' starting at 08/04/18 19:24:23, pid = 17713]
04/18/08 19:24:23.826423 zmdc[17563].ERR ['zmfilter.pl ' exited abnormally, exit status 9]
Anyone have any ideas what the cause might be?
Thanks a bunch!
Thanks a bunch!
Hi Cordel,
I am running v1.22.3
I have not previously upgraded.
I have deleted PWF filter and recreated.
I then stopped ZM, deleted all log files and started it again only to find same messages in zmdc.log and an empty zmfilter.log
I will have a read about serialization now but if you have any more suggestions I would be grateful.
