my pc two hhd wanted that in the second disc which this empty recorded all the events, that I must modify aside from ZM_DIR_EVENTS, ZM_DIR_IMAGES, ZM_DIR_SOUNDS?
mi equipo tiene dos hhd quisiera que en el segundo disco que esta vacio se grabaran todos los eventos, que debo modificar aparte de ZM_DIR_EVENTS, ZM_DIR_IMAGES, ZM_DIR_SOUNDS?
change directory and disc rec
- Victor1974
- Victor1974
- Victor1974
No comprendo lo de montar el driver /etc/fstab en /usr/share/zoneminder/events.
Mi fstab:
I do not understand "Then mount the new drive in /etc/fstab at /usr/share/zoneminder/events"
My fstab:
Mi fstab:
My fstab:
# /etc/fstab: static file system information.
# <file> <mount> <type> <options> <dump> <pass>
proc /proc proc defaults 0 0
# /dev/sda1
UUID=e877915b-c5fe-4060-911f-1c9dde2c254a / ext3 defaults,errors=remount-ro 0 1
# /dev/sda5
UUID=26238d97-5ee4-441b-ae52-93cab9165e16 none swap sw 0 0
/dev/scd0 /media/cdrom0 udf,iso9660 user,noauto,exec 0 0
/dev/sdb1 /cam ext2 nosuid,exec,nodev 0 0
- Victor1974
