Page 1 of 1
Running zoneminder
Posted: Wed Apr 23, 2008 6:25 am
by Cada
I have installed zoneminder and i can´t be able to put the console running, anybody can help to me?,
Thanks you very much.
Posted: Wed Apr 23, 2008 11:15 am
by vejeta
Please, give more detailed information so people can help you.
* What distribution did you use?
* What documentation did you follow to install it?
* Is the process running?
Check with: ps -ef|grep zm
* Have you checked the logs to see messages?
E.g.: Check the log archives:
/tmp/zmdc.log
/tmp/zmwatch.log
/tmp/zmpkg.log
/tmp/zmaudit.log
/var/log/messages
Posted: Mon Apr 28, 2008 11:52 am
by Cada
Hi Vejeta,
Thank you very much for your answer. I am using the 1.22.3 distribution. I have used the Manage Package of the last kubuntu version. The process is running and i have checked the log and i have found this:
"Restarting capture daemon for Prueba, shared memory not valid", Prueba is the name of my ip camera. Now the console is runnig but i can not see the video.
Best regards.
Posted: Mon Apr 28, 2008 12:14 pm
by vejeta
Can you see images when you are using other applications, like tvtime, xawtv.
If not, it could be you haven't configured the driver of your card to set the right card.
Saludos Cada.
Juan (Vejeta)
Posted: Mon Apr 28, 2008 1:36 pm
by Cada
Yes I can, i´m using for example the VLC software and it is perfect.
Posted: Mon Apr 28, 2008 2:46 pm
by vejeta
What are the access permissions for the video device?
Please, give the output of:
ls -l /dev/video*
What user is running the your www server?
ps -ef|grep http
Posted: Mon Apr 28, 2008 3:06 pm
by cordel
In order to be able to help you, it would be helpful to know:
What IP cam you are using and if it's on the supported IP cam list or not.
What settings you have tried for it in ZM.
Whether or not you have authentication turned on for the cam.
What errors you get n zmdc.log, Apache error_log, and messages.
etc, etc....
Also going to move this to the proper place as posting in 1.23.x for 1.22 is not organized.
Posted: Mon Apr 28, 2008 3:13 pm
by Cada
We have not got any Video* on /dev
The most likely are these:
cr--r--r-- 1 root root 61, 240 Oct 19 2006 camQ
cr--r--r-- 1 root root 61, 3 Oct 19 2006 cam3
cr--r--r-- 1 root root 61, 2 Oct 19 2006 cam2
cr--r--r-- 1 root root 61, 1 Oct 19 2006 cam1
cr--r--r-- 1 root root 61, 0 Oct 19 2006 cam0
The user is root. This is the line:
503 root 424 S /bin/boa -c /etc/httpd/conf
Have you goy any idea?.
Thank you very much
Best regards.
Posted: Mon Apr 28, 2008 5:31 pm
by Lee Sharp
cordel wrote:In order to be able to help you, it would be helpful to know:
Each camera is different, so this is needed.
