ZM 1.22.3 on Ubuntu 8.04 Hardy Heron
sl666
Location: The land downunder.. where women glow and men chunder, can you hear? can you hear the thunder?
Post by sl666 »
Hi Guys,
Just in case anyone was also doing this, I just thought i would post that i had success with installing 1.22.3 directly from synaptic and the 7.04 wiki article - http://www.zoneminder.com/wiki/index.php/Ubuntu_7.04.
except that after this
Then type this to reload the apache config
sudo /etc/init.d/apache2 reload
I did not get an image once i had set up a monitor, rebooted, and all worked, then after turning on authentication i had the same problem, but after a reboot it came good.
Details-
Ubuntu Hardy Heron 8.04 AMD64bit
AMD 4200+ dual core
ZM 1.22.3 (from the ubuntu package repository)
PV-149 4 port (running 2 cams) http://store.bluecherry.net/4_port_vide ... pv-149.htm
Cheers Steve.
