ZoneMinder 1.23.3 RPMs for SuSE released
Posted: Mon Apr 28, 2008 6:45 pm
RPM's for the new ZoneMinder version are now available in the repositories. Installation/upgrade instructions can be found in the wiki. Required perl modules, which are missing in the normal openSuSE distribution, are also in the repositories and get's installed when solving the dependencies.
Short summarize of the upgrade instructions:
SuSE 10.1:
http://liquid-co.de/pub/suse/repositori ... 23.2/10.1/
openSuSE 10.2:
http://liquid-co.de/pub/suse/repositori ... 23.2/10.2/
openSuSE 10.3:
http://liquid-co.de/pub/suse/repositori ... 23.2/10.3/
Note: This time the zm_database_init script uses a new approach: it generates (if not already exists) a .my.cnf (in folder root) which results in not typing in the root password (only for user root) every time you run the mysql client (as root) or the zm_database_script
Note: I just put the ZoneMinder (non MP) version to the openSuSE Build Service http://download.opensuse.org/repositori ... x:/stable/ so that you can find version for factory and SLED 10 there.
If you find some bugs please report this in the forums and mention that you are using the RPM's
Have a lot of Fun
Dirk
- To upgrade your current ZoneMinder RPM install, just stop ZoneMinder, install the new package and run zm_database_init which will the automatic call the original zm database upgrade script after path checking to the db scripts. (If your path in the config file is wrong zm_database_init will autocorrect the path. all you have to do is to answer the question for that with "y" or "yes"). After that start ZoneMinder by typing "rczm start" and all is done.
- The name has changed for the MP package. So if you want to upgrade the MP package you have to copy the old config by typing "cp /etc/zm.conf.rpmsave /etc/zm.conf" before you call zm_database_init. If you started ZoneMinder on boot then you have to rerun "chkconfig zm on".
- if you just want to update the database the traditional ZoneMinder way (it's recommended to use the wrapper zm_database_init script), edit /etc/zm.conf and change the version to the the new one (1.23.3) and check that ZM_PATH_BUILD is set to /srv/www/htdocs/zm. Then run "zmupdate.pl" and remove the lock file "rm -f /srv/www/htdocs/zm/lock" and start ZoneMinder.
SuSE 10.1:
openSuSE 10.2:
openSuSE 10.3:
Have a lot of Fun
Dirk
