1.23 CentOS install error
retrial5
Post by retrial5 »
When I run my ./configure with switches I get the following:
ZM requires PHP::Serialization.
I'm on CentOS 5.1. Can someone tell me the name of the package I need to download for this please?
Thanks.
zoneminder
Site Admin
Post by zoneminder »
I don't think this perl module is available via yum or any package managers in Centos yet. You can install it directly via perl by doing
perl -MSPAN -eshell
Say no when it asks you if you want to configure unless you want to answer a bunch of config questions. Then type
install PHP::Serialization
answering yes to any sensible questions and then
quit
Phil
mmartin
CentOS installation instructions
Post by mmartin »
Based on information found on this site, i created step by step installation instructions for CentOS 5 and Zoneminder 1.23.2 at http://www.mladekfamily.com/blog/storie ... 28/2314450
btw, easy way to install serialization
wget http://dag.wieers.com/rpm/packages/perl ... noarch.rpm
rpm -i perl-PHP-Serialization-0.27-1.el5.rf.noarch.rpm
