IVC-100-120-200G GPIO Module support
Posted: Fri May 02, 2008 4:13 pm
I've been using an IVC-200 from IEI with Zoneminder for some time and I've had very good experiences with it.
IEI also sells the same card with an integrated GPIO Module on it. So I bought on of those cards because a SDK for Linux was provided with the card, and the same setup would provide support for the IVC-100G and the IVC_120G as well.
The idea was to integrate an access control system with Zonemider and if Zoneminder raised an alarm via the GPIO module, access would be prevented.
However to my greatest disappointment I didn't manage to get that to work, and after weeks of googling on the internet I'm not even a step closer to a solution.
The problem is: How do I get Zoneminder to talk to the GPIO module.
Provided with the SDK are two files, a howto and a header file named sdk-howto and ieibt878.h.
The contents of the howto:
Any advise or help would be greatly appreciated.
The content of the header file ieibt878.hFirst of all, you must include the header file ieibt878.h in your application.
1. To use auto-detect function (detect signal removal automatically), use structure iei_auto_detect and VIDIOC_IEI_SET_AUTO_DETECT ioctl call. The rules are shown as below:
To enable auto-detect function, assign auto_detect to 1
To disable auto-detect function, assign auto_detect to 0
To get auto-detect function statue, use structure iei_auto_detect and VIDIOC_IEI_GET_AUTO_DETECT ioctl call.
2. To use auto-switch function (switch between channels automatically), use structure iei_auto_switch and VIDIOC_IEI_SET_AUTO_SWITCH ioctl call. The rules are shown as below:
To enable auto-switch function, assign auto_switch to 1
To disable auto-switch function, assign auto_switch to 0
To get auto-switch function statue, use structure iei_auto_switch and VIDIOC_IEI_GET_AUTO_SWITCH ioctl call.
3. To set channels, use structure iei_channel_mask and VIDIOC_IEI_SET_CHANNEL_MASK ioctl call. The rules are shown as below:
To enable/disable channel 1, assign bit 0 of ch_mask to 1/0
To enable/disable channel 2, assign bit 1 of ch_mask to 1/0
To enable/disable channel 3, assign bit 2 of ch_mask to 1/0
To enable/disable channel 4, assign bit 3 of ch_mask to 1/0
For example, if you want to enable channel 1 and 3 disable channel 2 and 4, you should assign ch_mask to 0x5.
To get channel status, use structure iei_channel_mask and VIDIOC_IEI_GET_CHANNEL_MASK ioctl call.
4. To set GPIO outputs, use structure iei_gpio and VIDIOC_IEI_SET_GPIO ioctl call. The rules are shown as below:
To set the output 1, assign bit 0 of gpio_target to 1 and bit 0 of gpio_value to 0 or 1
To set the output 2, assign bit 1 of gpio_target to 1 and bit 1 of gpio_value to 0 or 1
To set the output 3, assign bit 2 of gpio_target to 1 and bit 2 of gpio_value to 0 or 1
To set the output 4, assign bit 3 of gpio_target to 1 and bit 3 of gpio_value to 0 or 1
For example, if you want to set the output 1 and 3 to 0 and set the output 2 and 4 to 1, you should assign gpio_target to 0xf and gpio_value to 0xa.
To get GPIO inputs and outputs, use structure iei_gpio and VIDIOC_IEI_GET_GPIO ioctl call. The meaning of the returned value is shown as below:
gpio_target - don't care
gpio_value - bit 0 = input1, bit 1 = input 2, bit 2 = input 3, bit 3 = input 4, bit 4 = output 1, bit 5 = output 2, bit 6 = input 1, bit 7 = output 4
#ifndef _IEIBT878_H
#define _IEIBT878_H
struct iei_auto_switch
int auto_switch;
struct iei_channel_mask
int ch_mask;
struct iei_auto_detect
int auto_detect;
struct iei_gpio
int gpio_target;
int gpio_value;
struct iei_card_id
unsigned long dwSubsystemId;
unsigned long dwSubsystemVendorId;
struct iei_signal_status
int signal_status;
struct iei_norm_status
int is_525_scanline;
#define VIDIOC_IEI_SET_AUTO_SWITCH _IOW('v', 200, struct iei_auto_switch)
#define VIDIOC_IEI_GET_AUTO_SWITCH _IOR('v', 201, struct iei_auto_switch)
#define VIDIOC_IEI_SET_CHANNEL_MASK _IOW('v', 202, struct iei_channel_mask)
#define VIDIOC_IEI_GET_CHANNEL_MASK _IOR('v', 203, struct iei_channel_mask)
#define VIDIOC_IEI_SET_GPIO _IOW('v', 204, struct iei_gpio)
#define VIDIOC_IEI_GET_GPIO _IOR('v', 205, struct iei_gpio)
#define VIDIOC_IEI_GET_CARD_ID _IOR('v', 206, struct iei_card_id)
#define VIDIOC_IEI_GET_SIGNAL_STATUS _IOR('v', 207, struct iei_signal_status)
#define VIDIOC_IEI_SET_AUTO_DETECT _IOW('v', 208, struct iei_auto_detect)
#define VIDIOC_IEI_GET_AUTO_DETECT _IOR('v', 209, struct iei_auto_detect)
#define VIDIOC_IEI_GET_NORM_STATUS _IOR('v', 210, struct iei_norm_status)
#define ETIMEOUT 500 /* RISC command time-out */
#endif
