Camera Source Won't Connect
retrial5
Post by retrial5 »
I have ZM set up. I've used 1.22 with no issue, and have upgraded to CentOS with 1.23 now.
When i'm setting the source for my cameras i've tried dev/video and dev/video0 which are both valid paths. However, I can not get a video feed for either.
I've checked the camera and the infrared lights are on so I know it's getting power. I've tried using channel 0/1 as I have two cameras but I can't get an image from either.
Does anyone have suggestions?
Jason_Bassett
Post by Jason_Bassett »
Have you tried /dev/v4l/videoXX?
I found mine worked when I used the video nodes in there.
Last edited by Jason_Bassett on Thu Aug 19, 2010 10:57 am, edited 1 time in total.
Corrilan IT Consultancy Ltd
http://www.corrilan.com
01375 403508
enquiries@corrilan.com
retrial5
Post by retrial5 »
No such folder.
I've noted that video forwards itself to video0. So video0 is my obvious source.
retrial5
Post by retrial5 »
I still for the life of me can't get these cameras to show. The path is correct: dev/video0. am I missing a slash? Should it be /dev/video0 or dev/video0?
It's a 4 port card but uses a dongle. I've tried using all of the actual camera numbers but no feed. When I click on zones it's just a blank image with the red overlay.
Can someone please offer some assistance?
cordel
Post by cordel »
should be /dev/video0
Lee Sharp
Post by Lee Sharp »
To start, there are lots of 4 port cards. does it have 1 or 4 chips? That is your /dev/video0 through /dev/video3 if you have more than 1 chip. If you have a split chip, you will be using channels on /dev/video0 to get image. Not that in many cases the number on the pigtail has no relation to the software settings. Check all 4 as it could be numbered backwards.
This is assuming that your card is correctly configured, which is often not the case.
retrial5
Post by retrial5 »
I've tried all this, and Xawtv gives me permission denied when I try to ./configure or make as user or SU.
Im about to go back to Windows.
retrial5
Post by retrial5 »
Is a 1.23 liveCD available? I'm not sure why my card worked with Mandriva but is not with CentOS.
