Page 1 of 1
hardware compression card
Posted: Mon May 05, 2008 8:31 am
by pluttero
Hi guys,
I need to install a 4 analog (they're already deployed) cameras monitoring system I was thinking to use an hardware H264 compression card to lower the system load (the system should be up 24/7 and since it monitors crowded rooms, it will probably record from the 4 cameras at the same time). Does anybody have experience with hardware compression dvr cards and zone minder?
I was thinking to buy this one:
http://cgi.ebay.com/8-CHs-V-A-HD-compre ... m153.l1262
but if you have other suggestions...
thanks!
Paolo
Posted: Tue May 06, 2008 4:22 pm
by Lee Sharp
It does not work at all. ZM needs the uncompressed frame for motion detection.
Posted: Tue May 06, 2008 9:57 pm
by pluttero
I see. My problem is that I would need to capture smooth videos, so staying close to 25fps per channel would be very good. My hw is only a P4 1.5Ghz with 320GB (raid 0, a good 3ware card, not a fake raid) and 1GB ram. Even if I buy a real 120fps card, I don't think I would be able to record at full frame rate on each channel....So my only chance is to increase the hw?What would you suggest?
thanks!
Paolo
Posted: Wed May 07, 2008 4:32 pm
by Lee Sharp
I have had 4 ports get 20-30 fps on hardware worse than that. But bump the ram if you can.
