Weird lines again
apcyberax
Weird lines again
Post by apcyberax »
Hi all
i have had this problem before and no on could seem t help so i'm reaching out again in the hops that someone will have some ideas.
here is a screen shot of the cams...
http://www.aj-services.com/tmp/ScreenShot163.jpg
as you can see it lets alot of random lines over few frames. the lines are parts of the images from other cams on the system. its as if there not switching right.
I have 8 cams set to record only set at 1fps
i use 2x 4 port BT878 cards.
512mb ram
1.8ghz AMD CPU
500 gb IDE Hard drive
this problem only started then there were more then 2 cams on each card. please can anyone give me a idea.
