Black Image on Montage / empty image on stills
dom_
Post by dom_ »
I'm trying to set up zoneminder on gentoo.
the problem :
I can't get any image for any of my two webcam (stream nor stills).
I get an image when defining the zones.
stills
stream
zones
stream
logs
I tried to install with and without ffmpeg support plus various combinations for the settings. With firefox, conqueror and ie, the properties for the stills show a size of 0Ko.
Can you point me to some direction to solve this issue ?
Forgot to tell :
ZoneMinder Console - Running - v1.23.3
php 5.2.6-r1
apache 2.2.8
Regards,
Dom
edit : links errors
dom_
Post by dom_ »
Finally get it to work.
I guess adding cgi-bin path to the vhost config did not work correctly.
Copying the nph-zms and zms files to /var/www/localhost/cgi-bin/ seems
to do the job.
Also mpeg streaming does not work for me right now, jpeg does.
time to time when looking on the devices or on montage, the picture does not display or are not refreshed. Closing the popup window and retrying does the job.
Regards,
dom
