Panasonic Zoom control not working/Pan & Tilt are
cknox
Post by cknox »
NOTE: I have this issue posted in "Hardware Queries" as well. Yet, I don't think it's a hardware issue, as the Zoom feature works with the unit's proprietary software. It has to be a ZM configuration problem.
ZM version: 1.23.3
Linux flavor: OpenSuSE 10.3
Camera Hardware: PANASONIC BB-HCE481A (POE)
I edited PanasonicIP.pm and got the Pan right/left and tilt up/down controls to work using the command script returned by the Panasonic software; however, using the same for the zoom controls doesn't work. All the controls work using the Panasonic app. Do the Max/Min zoom range settings have to be set in the Control Capabilities? The "out of the box" ZM default PanasonicIP.pm script did not work either. The script changes I made are as follows:
sub zoomConTele
my $self = shift;
my $params = shift;
my $step = $self->getParam( $params, 'step' );
Debug( "Zoom Tele" );
my $cmd = "nphControlCamera?Direction=ZoomTele&Resolution=320x240&Quality=Motion&RPeriod=0&Size=STD&PresetOperation=Move&Language=0";
$self->sendCmd( $cmd );
sub zoomConWide
my $self = shift;
my $params = shift;
Debug( "Zoom Wide" );
my $cmd = "nphControlCamera?Direction=ZoomWide&Resolution=320x240&Quality=Motion&RPeriod=0&Size=STD&PresetOperation=Move&Language=0";
Someone please help!
cknox
zmcontrol.log output
Post by cknox »
Attached is the output of zmcontrol.log when trying to utilize the zoom funtionali
ZoneMinder::Control::PanasonicIP]
06/02/08 19:18:55.015273 zmcontrol[4817].INF [Starting control server 23/PanasonicIP]
06/02/08 19:18:55.018039 zmcontrol[4820].INF [Control server 23/PanasonicIP starting at 08/06/02 19:18:55]
06/02/08 19:18:56.039780 zmcontrol[4820].FAT [Can't access zoomRelWide member of object of class ZoneMinder::Control::PanasonicIP]
06/02/08 19:18:56.941179 zmcontrol[4829].INF [Starting control server 23/PanasonicIP]
06/02/08 19:18:56.949212 zmcontrol[4832].INF [Control server 23/PanasonicIP starting at 08/06/02 19:18:56]
06/02/08 19:18:57.954463 zmcontrol[4832].FAT [Can't access zoomRelWide member of object of class ZoneMinder::Control::PanasonicIP]
06/02/08 19:18:58.361034 zmcontrol[4834].INF [Starting control server 23/PanasonicIP]
06/02/08 19:18:58.364326 zmcontrol[4837].INF [Control server 23/PanasonicIP starting at 08/06/02 19:18:58]
06/02/08 19:18:59.384834 zmcontrol[4837].FAT [Can't access zoomRelWide member of object of class ZoneMinder::Control::PanasonicIP]
06/02/08 19:19:01.001378 zmcontrol[4846].INF [Starting control server 23/PanasonicIP]
06/02/08 19:19:01.004871 zmcontrol[4849].INF [Control server 23/PanasonicIP starting at 08/06/02 19:19:01]
06/02/08 19:19:02.014762 zmcontrol[4849].FAT [Can't access zoomRelTele member of object of class ZoneMinder::Control::PanasonicIP]
06/02/08 19:19:50.603223 zmcontrol[4952].INF [Starting control server 23/PanasonicIP]
06/02/08 19:19:50.606923 zmcontrol[4955].INF [Control server 23/PanasonicIP starting at 08/06/02 19:19:50]
06/02/08 19:20:54.801426 zmcontrol[4955].FAT [Can't access zoomRelWide member of object of class ZoneMinder::Control::PanasonicIP]
06/02/08 19:20:59.425696 zmcontrol[5095].INF [Starting control server 23/PanasonicIP]
06/02/08 19:20:59.428983 zmcontrol[5098].INF [Control server 23/PanasonicIP starting at 08/06/02 19:20:59]
06/02/08 19:21:00.438116 zmcontrol[5098].FAT [Can't access zoomRelTele member of object of class ZoneMinder::Control::PanasonicIP]
06/02/08 19:21:00.967300 zmcontrol[5100].INF [Starting control server 23/PanasonicIP]
06/02/08 19:21:00.970078 zmcontrol[5103].INF [Control server 23/PanasonicIP starting at 08/06/02 19:21:00]
