I Can't open video from file
danile
Post by danile »
I like test some situations with Zoneminder.
I have some videos that i like test. but when i add new monitor from source type as file, don't work.
Any help?
cordel
Post by cordel »
ZM is not able to capture from video files.
The file method is just for jpegs as an alternative for cams that for what ever reason ZM can not retrieve an image from directly.
coke
Post by coke »
Not sure what you're trying to accomplish, but if it would be helpful, it looks like Mplayer can save JPGs out of movie files, which you could then theoretically feed to ZM's file feature. Haven't tried it, but looks feasible.
danile
Post by danile »
So, zoneMinder only read jpg frames.
I have export video file frame by frame and save them as a jpg. But, how zoneminder read successive jpg frames?
