Page 1 of 1
CCTV analysis
Posted: Sun Jun 22, 2008 9:28 am
by Felicity Stanford
Hi
Does anyone know companies/organisations that would analyse video footage? I have some that was taken where a figure can be seen but the image is rather dark. I had infrared light at the time but this light is unusually reduced. The figure appears to be pointing something at the infared light.
thanks
Fliss
Posted: Sun Jun 22, 2008 7:23 pm
by kingofkya
Most likely for what you said the image is to dark you can try to use a filter in gimp and photoshop maybe but it not at all like TV where is magically happens with a click of a mouse thats all thous company do and some belending. Post screen shot maybe some one here can help i wouldn't be surprised
Posted: Sun Jun 22, 2008 7:56 pm
Hiya
That's a really good idea. We have paintshop pro but how do I take a clip out of an AVI and put it in paintshop pro?
Fliss
Posted: Sun Jun 22, 2008 9:46 pm
by kingofkya
Two ways i know of open vlc and right click on video and Select SnapShot or easyer go to zoneminder click export and select image files and it will give you all the jpeg images of every frame :D
Hope i helped
Posted: Sun Jun 22, 2008 10:01 pm
by cordel
kingofkya wrote:Two ways i know of open vlc and right click on video and save image or easyer go to zoneminder click export and select image files and it will give you all the jpeg images of every frame :D
Hope i helped
It's better to export the jpegs, most of the video codecs are very lossy so you will have more detail in the jpegs. avi is great for review or streaming but it's usefulness for keeping detail is limited.
Posted: Sun Jun 22, 2008 10:04 pm
by kingofkya
Yeah us the real pure jpegs off Zoneminder first should have made that more clear :shock:
Posted: Mon Jun 23, 2008 7:32 pm
Thanks for the tips. I'll give it a go. I'm really keen to keep the picture quality as true as possible.
Fliss
Posted: Mon Jun 23, 2008 7:46 pm
by coke
See if the image is RGB or greyscale. It probably looks greyscale, but I'm not sure what it ended up being. If it's RGB, make sure you check each channel seperately to see if one is cleaner than the others.
