Multiple Cameras - Single image
Mark Shahaf
Post by Mark Shahaf »
System: Suse 10.3 (kernel 2.6.22.5-31)
ZoneMinder: v1.23.3
I have 2 cameras attached to 2 USB ports. One is configured as /dev/video channel 0 and the second as /dev/video channel 1.
When watching the cameras from ZoneMinder I see the video from /dev/video0 on both!
Anybody struggled with such problem?
Mark
cordel
Post by cordel »
They should actualy be two different video devices. Check your dmesg and you should see one assigned to video0 and the other video1.
Mark Shahaf
I checked and they are. However the pictures I see are identical and are collected by video0. It seems that somehow video0 and video1 merged.
cordel
Post by cordel »
Can you post the webcam section of your dmesg please?
Not likely they merged as it don't work like that. It's more likely one has failed so your are left with one device.
Do you have these on seperate usb controlers?
Mark Shahaf
Single picture -dmesg
Thanks!
Below is dmesg output:
usb 5-1: new full speed USB device using uhci_hcd and address 2
usb 5-1: new device found, idVendor=093a, idProduct=2468
usb 5-1: new device strings: Mfr=1, Product=2, SerialNumber=0
usb 5-1: Product: CIF Single Chip
usb 5-1: Manufacturer: Pixart Imaging Inc.
usb 5-1: configuration #1 chosen from 1 choice
Linux video capture interface: v2.00
/usr/src/packages/BUILD/gspcav1-20071224/obj/default/gspca_core.c: USB GSPCA camera found. (PAC207)
/usr/src/packages/BUILD/gspcav1-20071224/obj/default/gspca_core.c: [spca5xx_probe:4275] Camera type GBRG
/usr/src/packages/BUILD/gspcav1-20071224/obj/default/gspca_core.c: [spca5xx_getcapability:1249] maxw 352 maxh 288 minw 160 minh 120
usbcore: registered new interface driver gspca
/usr/src/packages/BUILD/gspcav1-20071224/obj/default/gspca_core.c: gspca driver 01.00.20 registered
usbcore: registered new interface driver spca5xx
/usr/src/packages/BUILD/spca5xx-20060501/obj/default/drivers/usb/spca5xx.c: spca5xx driver 00.60.00 registered
usb 1-1: new full speed USB device using uhci_hcd and address 2
usb 1-1: new device found, idVendor=093a, idProduct=2468
usb 1-1: new device strings: Mfr=1, Product=2, SerialNumber=0
usb 1-1: Product: CIF Single Chip
usb 1-1: Manufacturer: Pixart Imaging Inc.
usb 1-1: configuration #1 chosen from 1 choice
/usr/src/packages/BUILD/gspcav1-20071224/obj/default/gspca_core.c: [spca5xx_set_light_freq:1932] Sensor currently not support light frequency banding filters.
/usr/src/packages/BUILD/gspcav1-20071224/obj/default/gspca_core.c: [gspca_set_isoc_ep:945] ISO EndPoint found 0x85 AlternateSet 8
/usr/src/packages/BUILD/gspcav1-20071224/obj/default/gspca_core.c: [spca5xx_do_ioctl:2124] Bridge PAC207BCA
AND many more lines like the last.
