No Images/Video with Creative Live Cam
eldwist
Post by eldwist »
Hello to all,
I've just installed ZM but I'm not able to see any images.
I've read the wiki, manual etc, but I'm not able to fix the problem.
I'm running Ubuntu 8.04 with ZM 1.23.x
Installation went fine.
Here is the lsusb result :
Bus 002 Device 005: ID 0a5c:2101 Broadcom Corp.
Bus 002 Device 004: ID 041e:4064 Creative Technology, Ltd
Bus 002 Device 003: ID 046d:c044 Logitech, Inc.
The WebCam is the Creative Live Cam , and works fine with VLC, Skype & Cheese.
Here is the zmu -q -d /dev/video0 -v results :
Video Capabilities
  Name: OV519 USB Camera
  Type: 513
    Can capture
    Can capture subareas of the image
  Video Channels: 1
  Audio Channels: 0
  Maximum Width: 640
  Maximum Height: 480
  Minimum Width: 64
  Minimum Height: 48
Window Attributes
  X Offset: 0
  Y Offset: 0
  Width: 640
  Height: 480
Picture Attributes
  Palette: 10 - YUV420
  Colour Depth: 12
  Brightness: 32768
  Hue: 26624
  Colour :0
  Contrast: 32768
  Whiteness: 26880
Channel 0 Attributes
  Channel: 0
  Flags: 0
  Type: 2 - Camera
  Format: 0 - PAL
I've also change the user privileges .
chmod 666 /dev/vide0
chmod 475 /usr/bin/zmfix
... but I'm still NOT able to get any image :(
Do you have any idea / suggestion ??
Thanks in advance for your help/tips
Kindest regards
Eld
