¿Variable fps when alarm occur?
raul_denia
Post by raul_denia »
Hi.
I am interested in save bandwidth because i will have 32 cameras in the same network.
I want that zoneminder capture 2 o 3 fps of each cameras, but when a alarm occur in a camera, i wish that automatic the fps upper to 25 fps for the camera that detect the alarm.
It is possible with options of zoneminder or is necessary to write a script in perl?
jameswilson
Post by jameswilson »
just set a normal fps at 2-3 and your alarm fps at 25, but you will need to use jpeg streaming from the cam, as mjpeg cannot be throttled
James Wilson
cordel
Post by cordel »
raul_denia
Ok, that's works.
Thanks.
