I have established that my Hauppague PVR 150 does not work as it uses the ivtv driver and not the bttv one.
As a result I am in the market for a new capture card and have seen these two:
http://www.maplin.co.uk/Module.aspx?Mod ... m8#specifi
http://www.maplin.co.uk/Module.aspx?Mod ... rd&doy=3m8
Does any one know if they will work? How can I tell / what do I need to look for to see if it will use the bttv drivers?
I have searched the forum for them with no luck, and I know that in the wiki there are cards that do work, but finding somewhere near me to buy one is a different matter! (Plus I don't want to spend loads - this is for a home system)
What do I look for in a capture card?
i have never seen such a big price for this kind of card. it is hard to tell without seeing chip on this card if it will work. i think You should rather look on ebay:
http://cgi.ebay.co.uk/CCTV-DVR-PCI-CAPT ... .m14.l1318
15£ for such a card is the biggest pricw i would give.
the moste safe choice (i think so) is to buy card with bt878 chip (conexant)
cheers
cheers
