Bug in PTZ control code
W.
Post by W. »
Found in 1.23.3, but most likely present in all previous versions as well.
Diagonal movements do not work ie UpRight, DownLeft etc.
Fix:
file web/zm_actions.php, line 462, replace regexp
'/^([a-z]+)([A-Z][a-z]+)([A-Z][a-z]+)$/'
with
'/^([a-z]+)([A-Z][a-z]+)([A-Z][A-Za-z]+)$/'
file web/zm_request_control.php, line 596, do the same replacement of regexp.
upd.
I just noticed that in other places Philip used
/^([a-z]+)([A-Z][a-z]+)([A-Z][a-z]+)+$/
, which probably works as well, but I did not test it.
if common sense is so uncommon, why is it called common then?
