Intermintent Video outtage
I am using ubuntu 8.0.4 and Zoneminder 1.23.3 everything seems to be working just fine execpt that ocassionaly i get blips of solid black video almost like the power or cam was unplugged for a half second then it comes back on, and most of time this triggers a record event. I cannot track this down as to what is doing this. as all cameras (7 of them) do this at least some of the time .the power supply is fine solid 13.8volts and the system is not being taxed.
anyone else ever come across this kind of problem?
What have you done so far to try to track it down?
What type of psu are you using for the cams?
I'd start off with two things, a DMM and a VCR.
The DMM should have the ability to store min/max voltages so you can place it on the circuit with the cam and turn it on, then you can go back and review the min recorded voltage at any time. It's the quickest way to find out if your supply is faulty or not.
The VCR you can place next to your server, put a tape in and plug the cam into it. You can use the composite output to loop the cam back into the server and hit record and note the time you started it so you can quickly reference the time diff and find sections easy. If you see the cam drop out on the vcr then you know to look at either the cams or their psu.
Other wise you would be looking at the capture card that is failing or maybe over heating.
Thanks for the tips I shall check this out right away and make sure that it isnt the PSU, i have a feeling it may be the card however I have also just noticed that if i click the event it comes up black then when i click still's the first 10 or so images are black and the last 6-7 are fine, also once in a while when the ZM console refreshes the video device is in RED then when i refresh it is back to green, even if the dev is in red i can still click on the stream and it will play but i wonder if that has something to do with it also? they are all ref'ed as /dev/video0 (0) 0 through 6
I would probably still do the above just as a sanity check but that tidbit of info sounds more towards the capture card or its driver failing.
Check your system logs and run dmesg, if the driver is having issues it usually shows up in one if not both. for some reason the dmesg log file does not always show the same things that running dmesg from the command line does so always refer to the dmesg from the command line as it will have any extra info after the machine boots.
40.292059] saa7130[7]: found at 0000:03:0f.0, rev: 1, irq: 16, latency: 32, mmio: 0xfe9fe000
[ 40.292066] saa7134: <rant>
[ 40.292067] saa7134: Congratulations! Your TV card vendor saved a few
[ 40.292068] saa7134: cents for a eeprom, thus your pci board has no
[ 40.292070] saa7134: subsystem ID and I can't identify it automatically
[ 40.292071] saa7134: </rant>
[ 40.292071] saa7134: I feel better now. Ok, here are the good news:
[ 40.292073] saa7134: You can use the card=<nr> insmod option to specify
[ 40.292074] saa7134: which board do you have. The list:
[ 40.292077] saa7134: card=0 -> UNKNOWN/GENERIC
[ 40.292080] saa7134: card=1 -> Proteus Pro [philips reference design] 1131:2001 1131:2001
[ 40.292085] saa7134: card=2 -> LifeView FlyVIDEO3000 5168:0138 4e42:0138
[ 40.292090] saa7134: card=3 -> LifeView/Typhoon FlyVIDEO2000 5168:0138 4e42:0138
[ 40.292094] saa7134: card=4 -> EMPRESS 1131:6752
[ 40.292097] saa7134: card=5 -> SKNet Monster TV 1131:4e85
[ 40.292101] saa7134: card=6 -> Tevion MD 9717
[ 40.292103] saa7134: card=7 -> KNC One TV-Station RDS / Typhoon TV Tune 1131:fe01 1894:fe01
[ 40.292107] saa7134: card=8 -> Terratec Cinergy 400 TV 153b:1142
[ 40.292111] saa7134: card=9 -> Medion 5044
[ 40.292114] saa7134: card=10 -> Kworld/KuroutoShikou SAA7130-TVPCI
[ 40.292116] saa7134: card=11 -> Terratec Cinergy 600 TV 153b:1143
[ 40.292120] saa7134: card=12 -> Medion 7134 16be:0003
[ 40.292123] saa7134: card=13 -> Typhoon TV+Radio 90031
[ 40.292126] saa7134: card=14 -> ELSA EX-VISION 300TV 1048:226b
[ 40.292129] saa7134: card=15 -> ELSA EX-VISION 500TV 1048:226a
[ 40.292133] saa7134: card=16 -> ASUS TV-FM 7134 1043:4842 1043:4830 1043:4840
[ 40.292137] saa7134: card=17 -> AOPEN VA1000 POWER 1131:7133
[ 40.292141] saa7134: card=18 -> BMK MPEX No Tuner
[ 40.292143] saa7134: card=19 -> Compro VideoMate TV 185b:c100
[ 40.292147] saa7134: card=20 -> Matrox CronosPlus 102b:48d0
[ 40.292150] saa7134: card=21 -> 10MOONS PCI TV CAPTURE CARD 1131:2001
[ 40.292153] saa7134: card=22 -> AverMedia M156 / Medion 2819 1461:a70b
[ 40.292157] saa7134: card=23 -> BMK MPEX Tuner
[ 40.292160] saa7134: card=24 -> KNC One TV-Station DVR 1894:a006
[ 40.292163] saa7134: card=25 -> ASUS TV-FM 7133 1043:4843
[ 40.292166] saa7134: card=26 -> Pinnacle PCTV Stereo (saa7134) 11bd:002b
[ 40.292170] saa7134: card=27 -> Manli MuchTV M-TV002/Behold TV 403 FM
[ 40.292172] saa7134: card=28 -> Manli MuchTV M-TV001/Behold TV 401
[ 40.292175] saa7134: card=29 -> Nagase Sangyo TransGear 3000TV 1461:050c
[ 40.292178] saa7134: card=30 -> Elitegroup ECS TVP3XP FM1216 Tuner Card( 1019:4cb4
[ 40.292182] saa7134: card=31 -> Elitegroup ECS TVP3XP FM1236 Tuner Card 1019:4cb5
[ 40.292185] saa7134: card=32 -> AVACS SmartTV
[ 40.292188] saa7134: card=33 -> AVerMedia DVD EZMaker 1461:10ff
[ 40.292191] saa7134: card=34 -> Noval Prime TV 7133
[ 40.292194] saa7134: card=35 -> AverMedia AverTV Studio 305 1461:2115
[ 40.292197] saa7134: card=36 -> UPMOST PURPLE TV 12ab:0800
[ 40.292201] saa7134: card=37 -> Items MuchTV Plus / IT-005
[ 40.292203] saa7134: card=38 -> Terratec Cinergy 200 TV 153b:1152
[ 40.292207] saa7134: card=39 -> LifeView FlyTV Platinum Mini 5168:0212 4e42:0212
[ 40.292211] saa7134: card=40 -> Compro VideoMate TV PVR/FM 185b:c100
[ 40.292214] saa7134: card=41 -> Compro VideoMate TV Gold+ 185b:c100
[ 40.292218] saa7134: card=42 -> Sabrent SBT-TVFM (saa7130)
[ 40.292220] saa7134: card=43 -> :Zolid Xpert TV7134
[ 40.292223] saa7134: card=44 -> Empire PCI TV-Radio LE
[ 40.292226] saa7134: card=45 -> Avermedia AVerTV Studio 307 1461:9715
[ 40.292229] saa7134: card=46 -> AVerMedia Cardbus TV/Radio (E500) 1461:d6ee
[ 40.292232] saa7134: card=47 -> Terratec Cinergy 400 mobile 153b:1162
[ 40.292236] saa7134: card=48 -> Terratec Cinergy 600 TV MK3 153b:1158
[ 40.292239] saa7134: card=49 -> Compro VideoMate Gold+ Pal 185b:c200
[ 40.292243] saa7134: card=50 -> Pinnacle PCTV 300i DVB-T + PAL 11bd:002d
[ 40.292246] saa7134: card=51 -> ProVideo PV952 1540:9524
[ 40.292249] saa7134: card=52 -> AverMedia AverTV/305 1461:2108
[ 40.292253] saa7134: card=53 -> ASUS TV-FM 7135 1043:4845
[ 40.292256] saa7134: card=54 -> LifeView FlyTV Platinum FM / Gold 5168:0214 5168:5214 1489:0214 5168:0304
[ 40.292261] saa7134: card=55 -> LifeView FlyDVB-T DUO / MSI TV@nywhere D 5168:0306 4e42:0306
[ 40.292265] saa7134: card=56 -> Avermedia AVerTV 307 1461:a70a
[ 40.292269] saa7134: card=57 -> Avermedia AVerTV GO 007 FM 1461:f31f
[ 40.292272] saa7134: card=58 -> ADS Tech Instant TV (saa7135) 1421:0350 1421:0351 1421:0370 1421:1370
[ 40.292278] saa7134: card=59 -> Kworld/Tevion V-Stream Xpert TV PVR7134
[ 40.292281] saa7134: card=60 -> LifeView/Typhoon/Genius FlyDVB-T Duo Car 5168:0502 4e42:0502 1489:0502
[ 40.292285] saa7134: card=61 -> Philips TOUGH DVB-T reference design 1131:2004
[ 40.292289] saa7134: card=62 -> Compro VideoMate TV Gold+II
[ 40.292291] saa7134: card=63 -> Kworld Xpert TV PVR7134
[ 40.292294] saa7134: card=64 -> FlyTV mini Asus Digimatrix 1043:0210
[ 40.292298] saa7134: card=65 -> V-Stream Studio TV Terminator
[ 40.292300] saa7134: card=66 -> Yuan TUN-900 (saa7135)
[ 40.292303] saa7134: card=67 -> Beholder BeholdTV 409 FM 0000:4091
[ 40.292307] saa7134: card=68 -> GoTView 7135 PCI 5456:7135
[ 40.292310] saa7134: card=69 -> Philips EUROPA V3 reference design 1131:2004
[ 40.292313] saa7134: card=70 -> Compro Videomate DVB-T300 185b:c900
[ 40.292317] saa7134: card=71 -> Compro Videomate DVB-T200 185b:c901
[ 40.292320] saa7134: card=72 -> RTD Embedded Technologies VFG7350 1435:7350
[ 40.292323] saa7134: card=73 -> RTD Embedded Technologies VFG7330 1435:7330
[ 40.292327] saa7134: card=74 -> LifeView FlyTV Platinum Mini2 14c0:1212
[ 40.292330] saa7134: card=75 -> AVerMedia AVerTVHD MCE A180 1461:1044
[ 40.292333] saa7134: card=76 -> SKNet MonsterTV Mobile 1131:4ee9
[ 40.292337] saa7134: card=77 -> Pinnacle PCTV 40i/50i/110i (saa7133) 11bd:002e
[ 40.292340] saa7134: card=78 -> ASUSTeK P7131 Dual 1043:4862 1043:4857
[ 40.292344] saa7134: card=79 -> Sedna/MuchTV PC TV Cardbus TV/Radio (ITO
[ 40.292347] saa7134: card=80 -> ASUS Digimatrix TV 1043:0210
[ 40.292350] saa7134: card=81 -> Philips Tiger reference design 1131:2018
[ 40.292354] saa7134: card=82 -> MSI TV@Anywhere plus 1462:6231
[ 40.292357] saa7134: card=83 -> Terratec Cinergy 250 PCI TV 153b:1160
[ 40.292360] saa7134: card=84 -> LifeView FlyDVB Trio 5168:0319
[ 40.292364] saa7134: card=85 -> AverTV DVB-T 777 1461:2c05 1461:2c05
[ 40.292368] saa7134: card=86 -> LifeView FlyDVB-T / Genius VideoWonder D 5168:0301 1489:0301
[ 40.292372] saa7134: card=87 -> ADS Instant TV Duo Cardbus PTV331 0331:1421
[ 40.292376] saa7134: card=88 -> Tevion/KWorld DVB-T 220RF 17de:7201
[ 40.292379] saa7134: card=89 -> ELSA EX-VISION 700TV 1048:226c
[ 40.292382] saa7134: card=90 -> Kworld ATSC110/115 17de:7350 17de:7352
[ 40.292386] saa7134: card=91 -> AVerMedia A169 B 1461:7360
[ 40.292390] saa7134: card=92 -> AVerMedia A169 B1 1461:6360
[ 40.292393] saa7134: card=93 -> Medion 7134 Bridge #2 16be:0005
[ 40.292396] saa7134: card=94 -> LifeView FlyDVB-T Hybrid Cardbus/MSI TV 5168:3306 5168:3502 4e42:3502
[ 40.292401] saa7134: card=95 -> LifeView FlyVIDEO3000 (NTSC) 5169:0138
[ 40.292405] saa7134: card=96 -> Medion Md8800 Quadro 16be:0007 16be:0008
[ 40.292409] saa7134: card=97 -> LifeView FlyDVB-S /Acorp TV134DS 5168:0300 4e42:0300
[ 40.292413] saa7134: card=98 -> Proteus Pro 2309 0919:2003
[ 40.292417] saa7134: card=99 -> AVerMedia TV Hybrid A16AR 1461:2c00
[ 40.292420] saa7134: card=100 -> Asus Europa2 OEM 1043:4860
[ 40.292424] saa7134: card=101 -> Pinnacle PCTV 310i 11bd:002f
[ 40.292427] saa7134: card=102 -> Avermedia AVerTV Studio 507 1461:9715
[ 40.292430] saa7134: card=103 -> Compro Videomate DVB-T200A
[ 40.292433] saa7134: card=104 -> Hauppauge WinTV-HVR1110 DVB-T/Hybrid 0070:6701
[ 40.292436] saa7134: card=105 -> Terratec Cinergy HT PCMCIA 153b:1172
[ 40.292440] saa7134: card=106 -> Encore ENLTV 1131:2342 1131:2341 3016:2344
[ 40.292445] saa7134: card=107 -> Encore ENLTV-FM 1131:230f
[ 40.292448] saa7134: card=108 -> Terratec Cinergy HT PCI 153b:1175
[ 40.292451] saa7134: card=109 -> Philips Tiger - S Reference design
[ 40.292454] saa7134: card=110 -> Avermedia M102 1461:f31e
[ 40.292458] saa7134: card=111 -> ASUS P7131 4871 1043:4871
[ 40.292461] saa7134: card=112 -> ASUSTeK P7131 Hybrid 1043:4876
[ 40.292465] saa7134: card=113 -> Elitegroup ECS TVP3XP FM1246 Tuner Card 1019:4cb6
[ 40.292468] saa7134: card=114 -> KWorld DVB-T 210 17de:7250
[ 40.292471] saa7134: card=115 -> Sabrent PCMCIA TV-PCB05 0919:2003
[ 40.292475] saa7134: card=116 -> 10MOONS TM300 TV Card 1131:2304
[ 40.292478] saa7134: card=117 -> Avermedia Super 007 1461:f01d
[ 40.292483] saa7130[7]: subsystem: 1131:0000, board: UNKNOWN/GENERIC [card=0,autodetected]
[ 40.292503] saa7130[7]: board init: gpio is 10000
[ 40.395648] saa7130[7]: Huh, no eeprom present (err=-5)?
[ 40.395721] saa7130[7]: registered device video7 [v4l2]
[ 40.395750] saa7130[7]: registered device vbi7
[ 40.396020] NVRM: loading NVIDIA UNIX x86 Kernel Module 169.12 Thu Feb 14 17:53:07 PST 2008
[ 40.397127] ACPI: PCI Interrupt 0000:02:03.0[A] -> GSI 19 (level, low) -> IRQ 17
[ 40.580512] saa7134 ALSA driver for DMA sound loaded
[ 40.580555] saa7130[0]/alsa: saa7130[0] at 0xfe9ffc00 irq 21 registered as card -2
[ 40.580956] saa7130[1]/alsa: saa7130[1] at 0xfe9ff800 irq 18 registered as card -1
[ 40.581297] saa7130[2]/alsa: saa7130[2] at 0xfe9ff400 irq 17 registered as card -1
[ 40.581642] saa7130[3]/alsa: saa7130[3] at 0xfe9ff000 irq 16 registered as card -1
[ 40.582018] saa7130[4]/alsa: saa7130[4] at 0xfe9fec00 irq 21 registered as card -1
[ 40.582384] saa7130[5]/alsa: saa7130[5] at 0xfe9fe800 irq 18 registered as card -1
[ 40.582738] saa7130[6]/alsa: saa7130[6] at 0xfe9fe400 irq 17 registered as card -1
I'm sure this must have somethig to do with it sadly i have no clue as i am new at the linux hardware thing. this is a 8 port video capture card
http://cgi.ebay.ca/9-bit-8-CH-video-rea ... dZViewItem
this it the one i have in there.
when i am in montage or single view it works great execpt for that blip and that it records the first bit of black then the images
Okay so the good news is this card can work in linux as you are able to get video from it.
The bad news is that V4L has no idea of what driver to use for it and is using a generic driver. You will have to try to find out what driver to use.
You can use:
scanpci -v
to get more information on the card, then use this ("CardVendor 0x0070 card 0x13eb" or " vendor 0x109e device 0x036e" for example) information in google to see if someone has found the correct device number to modprobe the correct driver.
Or attempt to find your card in this long list at link.
Otherwise you will have to go through each device number to find what works, what don't, then figure out what works best.
You can use:
scanpci -v
ok thanks i shall do some research on that to hopefully make things happier, on the upside i delte all my cameras and readded them and the problem "seems" to have gone away in the recording the b lips are still in the live views but no tin the recordeing UNTILL i change the resolution from 320x240 to anythign else then i start getting errors untill i make sure every cam is 320x240 and restart zoneminder.
thanks for the help much appreciated
lspci -v yeilds
03:08.0 Multimedia controller: Philips Semiconductors SAA7130 Video Broadcast Decoder (rev 01)
Subsystem: Philips Semiconductors Unknown device 0000
Flags: bus master, medium devsel, latency 32, IRQ 21
Memory at fe9ffc00 (32-bit, non-prefetchable)
Capabilities: <access>
03:09.0 Multimedia controller: Philips Semiconductors SAA7130 Video Broadcast Decoder (rev 01)
Flags: bus master, medium devsel, latency 32, IRQ 18
Memory at fe9ff800 (32-bit, non-prefetchable)
03:0a.0 Multimedia controller: Philips Semiconductors SAA7130 Video Broadcast Decoder (rev 01)
Flags: bus master, medium devsel, latency 32, IRQ 17
Memory at fe9ff400 (32-bit, non-prefetchable)
03:0b.0 Multimedia controller: Philips Semiconductors SAA7130 Video Broadcast Decoder (rev 01)
Flags: bus master, medium devsel, latency 32, IRQ 16
Memory at fe9ff000 (32-bit, non-prefetchable)
03:0c.0 Multimedia controller: Philips Semiconductors SAA7130 Video Broadcast Decoder (rev 01)
Memory at fe9fec00 (32-bit, non-prefetchable)
03:0d.0 Multimedia controller: Philips Semiconductors SAA7130 Video Broadcast Decoder (rev 01)
Memory at fe9fe800 (32-bit, non-prefetchable)
03:0e.0 Multimedia controller: Philips Semiconductors SAA7130 Video Broadcast Decoder (rev 01)
Memory at fe9fe400 (32-bit, non-prefetchable)
03:0f.0 Multimedia controller: Philips Semiconductors SAA7130 Video Broadcast Decoder (rev 01)
Memory at fe9fe000 (32-bit, non-prefetchable)
[RANT]
Glad to see that Ubuntu is always making things easier
Wonder what their reasoning is for omitting one of the most common tools.
We can get most of the same info through lspci I just hate it as it replaces the description with the ID codes so you can't have both so it makes you have to think a bit harder than should be required and type twice as much or more unless I'm missing something.
[/RANT]
lspci -vn -s 03:08.0
The rest should all be the same, but can't say for sure as I have never used lspci for this because of it's short comings.
lspci -vn -s 03:09.0
lspci -vn -s 03:0a.0
lspci -vn -s 03:0b.0
lspci -vn -s 03:0c.0
lspci -vn -s 03:0d.0
lspci -vn -s 03:0e.0
lspci -vn -s 03:0f.0
Or you can do lspci -vn and it shows everything without the descriptions, still really annoying. Although I'm not sure it will get the info we really need.
[/RANT]
03:08.0 0480: 1131:7130 (rev 01)
Subsystem: 1131:0000
Capabilities: [40] Power Management version 1
03:09.0 0480: 1131:7130 (rev 01)
03:0a.0 0480: 1131:7130 (rev 01)
03:0b.0 0480: 1131:7130 (rev 01)
03:0c.0 0480: 1131:7130 (rev 01)
03:0d.0 0480: 1131:7130 (rev 01)
03:0e.0 0480: 1131:7130 (rev 01)
03:0f.0 0480: 1131:7130 (rev 01)
