Warnings in zmdc.log
victor_diago
Post by victor_diago »
im getting the following error :
Caution : Quantization tables are too coarse for baseline jpeg .
Do anyone know why ?
also, i had the 145 problem in Frames.MYI in mysql... i ´ve runned myisamchk -r and its all right now... anyone know why ?, it told me that 2 clients didnt closed the table ....
zoneminder
Site Admin
Re: Warnings in zmdc.log
Post by zoneminder »
Hi Victor,
These are warning from libjpeg.a though I don't know what they mean. Do you have a really low quality value for your images?
I'm not sure what the '145' error you are referring to is though. If you explain I'll try to help further.
Phil,
qriff
Post by qriff »
I confirm this...
Running ZM v1.22.3, using a generic one-chip four-port bt878 on a dual-processor p3 with 256Mb memory. (Gentoo)
With ZM_JPEG_IMAGE_QUALITY set bellow 25 (%) there will be a warning
10/07/07 14:41:16.762567 zms[4708].INF-zm_jpeg.c/72 [Caution: quantization tables are too coarse for baseline JPEG]
