zoneminder_1.23.3-2_i386.deb FFMPEG SUPPORT!! REALLY!!!
This time for sure!!!
I need some testers for this. I've got things working for me, including video export, but I've had things work for me and noone else before . . . so those of you who have been asking about it, please try it and let me know.
The package is Ubuntu gutsy/hardy - ftp://ftp.northern-ridge.com.au/zonemin ... 2_i386.deb - If there are any debian sid people out there who want to try it, let me know and I'll provide the equivalent debian package.
The one change I know you need to make after installing is on the "Images" tab of the options page. Change ZM_PATH_FFMPEG to /usr/bin/ffmpeg (rather than the /usr/local/bin/ffmpeg it starts as)
Once I know it's working for others, I'll release a -3 with some other bits fixed as the "real" release (which will go in the debian repo as well)
PJH
PJH
Peter,
I just installed your deb file. So far it's working great. Here is my setup:
Ubuntu 8.04 Server
loaded LAMP and OpenSSH during installation
after installation ran
downloaded your debfile and ran
got dependency errors and ran
which resolved dependencies and finished the installation.
After that I ran
followed by
last i changed the option ZM_PATH_FFMPEG to /usr/bin/ffmpeg
Done and working
So far I enabled webcam support and linked to another Zoneminder. So far everything is working great. That was my fastest installation yet (less than 10 min).
Thanks!
Ubuntu 8.04 Server
sudo apt-get update
sudo apt-get upgrade
sudo dpkg -i zoneminder_1.23.3-2_i386.deb
sudo apt-get install -f
After that I ran
sudo /etc/init.d/apache2 reload
Done and working
Thanks!
Hmmmm. . . not sure what I can do about that one.kingofkya wrote:Two bugs found
if the mythbuntue version of ffmpeg is installed it fails
Can you give me some more error information for that one?also if deep filesystem hierarchy is on live mpeg streams and video creation fail(may be zm bug)
Thanks for the feedback.
PJH
I have a major deadline at work for Sep 12. I won't be thinking about that much else between now and then. After that . . . I think I'll take you up (Lee) on your offer of some space on a 64-bit install. . .I had been hoping to do a reinstall of my server and take it from 32 to 64 bit in the second half of Sep but I'm not sure I'll have the time now.Lee Sharp wrote:Me too. To both statements.foreverg wrote:great peter!
I'm testing it on x86 plattform.. Is a 64bit version scheduled?
PJH
Unable to create mpeg videos from event images
I installed the .deb on Ubuntu 8.04 server with no problems.
I am having the problem documented in this thread:
http://www.zoneminder.com/forums/viewtopic.php?t=11036
in that I cannot stream if ZM_AUTH_RELAY is set to hashed.
It does work if ZM_AUTH_RELAY is set to plain or none.
A more important issue may be that I do not get the "Video" link in the Event view window, and so I do not have any way to create an mpeg from the images in the event.
Other than that, everything seems to be working great.
Thanks for putting together this .deb!!
You would say that now that my 64 bit server has been "realigned..."PeterHoward wrote:I have a major deadline at work for Sep 12. I won't be thinking about that much else between now and then. After that . . . I think I'll take you up (Lee) on your offer of some space on a 64-bit install. . .I had been hoping to do a reinstall of my server and take it from 32 to 64 bit in the second half of Sep but I'm not sure I'll have the time now.
As an aside, I have been running the new version on 3 systems with no problems. Nice job!
I tried your deb, It' s working well
http://www.zoneminder.com/forums/viewtopic.php?t=12261
without changing ffmpeg path...
Re: Unable to create mpeg videos from event images
Sadly, that's life using gnutls at the moment (I'm not saying it's a problem with gnutls; but using it with zoneminder has issues which I haven't gotten around to looking atnachbar wrote:I installed the .deb on Ubuntu 8.04 server with no problems.
Hmmmm. In the "Images" tab on the "options" window have you changed ZM_OPT_MPEG from "none" to "ffmpeg"? Assuming you changed ZM_PATH_FFMPEG as described above, I can't think of anything else.
PJH
