Dlink DCS-910
Dlink DCS-910
I've read in the wkiki about the dlink DSC-900 that works with zoneminder. I'm planning to buy one DCS-900 but seems to be out of stock but thde DCS-910 and DCS-920 are on the store.
Is the DCS-910 and/or DCS-902 models supported to work with zoneminder?
Best regards,
Best regards,
I too am interested if the DCS-910 works with ZM. It seems to be the new version of the DCS-900, but who knows what they did to it.
http://www.dlink.com/products/?pid=665
DCS-910
I want to test that camera, if I buy it I'll post the results.
But with the help of google I found this page.
http://translate.google.com/translate?h ... l%26sa%3DG
There is a comment about this camera, where you can take out video from /mjpeg.cgi (only with avreg)
and snapshots with /image.jpg
Anyone knows if avreg is implemented in zm?
DCS-910 WORKS!?
OK I bought it.
I tested it in zoneminder 1.23.3 with the ZM_NETCAM_REGEXPS (Options - Network) unchecked, on the "/video.cgi?" path.
And I have to say that I got image.
It just needs more testing but it seems to work.
I mean, if I got an image it should mean that it works, but please if there is anyone with more knowledge than me, just tell me what else to do.
DCS-910 works on zoneminder(edited)
This is final, this dlink dcs-910 works, but I do not recommend it !! (edited this so that you keep reading this topic)
only tried the /video.cgi? as mjpg stream. have not tried the jpeg mode.
just remember the regular_expresion parameter on the network options.
640x480 image quality very poor!
R
that's strange.
I tried with another user and admin , both worked fine.
I got 640x480, remember you have to change the resolution on the camera and zoneminder, both.
you should be able to change the password, try to create another user fist, verify it works and then change the admin password. Anyway you can always reset the camera.
I have that box unchecked, I have restarted zoneminder, I have deleted the cameras and added them fresh as 640x480, when I go to /var/log/zm/ there is nothing in that dir? The cameras are set as 640x480, and I see them as that when I go to their IP Address. I am running the latest firmware on them 1.01.
Still Works
So if you set the remote host path to: /video.cgi?
it works, but only for Stills, not Steam.
I'm not sure what to do to fix it.
Help?
Can you help me then, I also noticed that i only see "Still" when its resolution is at 320x240, if i move it to 640x480 i don't see "Still or Stream". I have installed the ffmpeg and cambozola. I have altered the path boxes to reflect their locations. I'm not super familiar with ubuntu/linux so any help would be appreciated.
Thanks,
Coz
Thanks,
Coz
