Name this file as "VivotekPT7135.pm" and copy under "control" perl modules.
# This module contains the implementation of the Vivotek PT7135 protocol
# It is easy to adapt to other Vivotek cameras. I have found a lot of commands with Wireshark
# This protocol get some info from the camera through receiveCmd function.
# Implement a pseudo diagonal movement
# Where go "presetClear" function from php code?
# Any improve is welcome, and please share it
# Normando Hall nhall[AT]unixlan[DOT]com[DOT]ar
package ZoneMinder::Control::VivotekPT7135;
use 5.006;
use strict;
use warnings;
require ZoneMinder::Base;
require ZoneMinder::Control;
# Vivotek PT7135 Control Protocol
use Time::HiRes qw( usleep );
sub new
my $class = shift;
my $id = shift;
bless( $self, $class );
srand( time() );
return $self;
our $AUTOLOAD;
sub AUTOLOAD
my $self = shift;
my $name = $AUTOLOAD;
$name =~ s/.*://;
if ( exists($self->{$name}) )
return( $self->{$name} );
sub open
my $self = shift;
$self->loadMonitor();
use LWP::UserAgent;
$self->{state} = 'open';
sub close
my $self = shift;
$self->{state} = 'closed';
sub printMsg
my $self = shift;
my $msg = shift;
my $msg_len = length($msg);
sub sendCmd
my $self = shift;
my $cmd = shift;
my $result = undef;
printMsg( $cmd, "Tx" );
#print( "http://$address/$cmd\n" );
if ( $res->is_success )
$result = !undef;
else
return( $result );
sub receiveCmd
my $self = shift;
my $cmd = shift;
my $result = undef;
printMsg( $cmd, "Rx" );
my $content = $res->content();
$result = $content;
else
return( $result );
sub reset
my $self = shift;
Debug( "Camera Reset" );
my $cmd = "/cgi-bin/admin/setparam.cgi?System_Reset=3";
$self->sendCmd( $cmd );
sub moveMap
my $self = shift;
my $params = shift;
my $xcoord = $self->getParam( $params, 'xcoord' );
my $ycoord = $self->getParam( $params, 'ycoord' );
my $imagewidth = $self->{Monitor}->{Width};
my $imageheight = $self->{Monitor}->{Height};
Debug( "Move Map to $xcoord,$ycoord at $imagewidth/$imageheight" );
if ( $imagewidth == "640" )
$xcoord = $xcoord/2;
$ycoord = $ycoord/2;
my $cmd = "/cgi-bin/camctrl.cgi?cam1&x=$xcoord&y=$ycoord";
sub moveRelUp
my $self = shift;
my $params = shift;
my $tiltspeed = $self->getParam( $params, 'tiltspeed' );
Debug( "Move Up - Speed $tiltspeed" );
my $cmd = "/cgi-bin/camctrl.cgi?move=up&speedtilt=$tiltspeed";
sub moveRelDown
my $self = shift;
my $params = shift;
Debug( "Move Down - Speed $tiltspeed" );
my $cmd = "/cgi-bin/camctrl.cgi?move=down&speedtilt=$tiltspeed";
sub moveRelLeft
my $self = shift;
my $params = shift;
my $panspeed = $self->getParam( $params, 'panspeed' );
Debug( "Move Left - Speed $panspeed" );
my $cmd = "/cgi-bin/camctrl.cgi?move=left&speedpan=$panspeed";
sub moveRelRight
my $self = shift;
my $params = shift;
Debug( "Move Right - Speed $panspeed" );
my $cmd = "/cgi-bin/camctrl.cgi?move=right&speedpan=$panspeed";
sub moveRelUpRight
my $self = shift;
my $params = shift;
Debug( "Move Up/Right - Speed $tiltspeed/$panspeed" );
sub moveRelUpLeft
my $self = shift;
my $params = shift;
Debug( "Step Up/Left - Speed $tiltspeed/$panspeed" );
sub moveRelDownRight
my $self = shift;
my $params = shift;
Debug( "Step Down/Right - Speed $tiltspeed/$panspeed" );
sub moveRelDownLeft
my $self = shift;
my $params = shift;
Debug( "Step Down/Left - Speed $tiltspeed/$panspeed" );
sub whiteAuto
my $self = shift;
Debug( "White Auto" );
my $cmd = "/cgi-bin/admin/setparam.cgi?Video_Whitebalance=0";
sub whiteMan
my $self = shift;
Debug( "White Man" );
my $cmd = "/cgi-bin/admin/setparam.cgi?Video_Whitebalance=2";
sub In
my $self = shift;
Debug( "White In" );
my $cmd = "/cgi-bin/admin/setparam.cgi?Video_Whitebalance=1";
sub Out
my $self = shift;
Debug( "White Out" );
my $cmd = "/cgi-bin/admin/setparam.cgi?Video_Whitebalance=3";
sub presetClear
my $self = shift;
my $params = shift;
my $preset = ( $preset - 1 );
Debug( "Clear Preset $preset" );
my $cmd = "/cgi-bin/admin/preset.cgi?delpos=$preset&Submit=Delete";
sub presetSet
my $self = shift;
my $params = shift;
my $cmd = "/cgi-bin/admin/getparam.cgi?camctrl_axisx";
my $rx = $self->receiveCmd( $cmd );
my ($axisx) = $rx =~ /([-0-9]+)/;
my $cmd = "/cgi-bin/admin/getparam.cgi?camctrl_axisy";
my ($axisy) = $rx =~ /([-0-9]+)/;
Debug( "Set Preset $preset at $axisx and $axisy" );
my $cmd = "/cgi-bin/admin/setparam.cgi?camctrl_presetname_$preset=$preset&camctrl_presetpan_$preset=$axisx&camctrl_presettilt_$preset=$axisy";
sub presetGoto
my $self = shift;
my $params = shift;
my $cmd = "/cgi-bin/recall.cgi?recall=$preset";
sub presetHome
my $self = shift;
Debug( "Home Preset" );
my $cmd = "/cgi-bin/camctrl.cgi?move=home";
1;
__END__
Controllable: check
Control Device: none
Control Address: the camera IP, or user:pass@camera_ip
Return Location: Home
Then click on "Edit" link at "Control Type" to create the new control module in the db.
At the new window click at the "Create New Control" button.
MAIN:
Type: Remote
Protocol: VivotekPT7135
Can Reset: Check
MOVE
Can Move: check
Can Move Diagonally: check
Can Move Mapped: check
Can Move Relative: check
PAN
Can Pan: check
Has Pan Speed: check
Min Pan Speed: -5
Max Pan Speed: 5
TILT
Can Tilt: check
Has Tilt Speed: check
Min Tilt Speed: -5
Max Tilt Speed: 5
WHITE
Can White Balance: check
Can Auto White Bal.: check
PRESETS
Has Presets: check
Num Presets: 20
Can Set Presets: check
At your monitor window, refresh and selec from the pull-down list "Vivotek PT7135" at the "Control Type" field.
Save and enjoy
