ubuntu 8.04 - zoneminder 1.23.3 - kernel 2.6.24-16 8ch GUIDE
recidivo
Post by recidivo »
I worked soo much, but now everything is working well, this is a post for newbies but also for anyone like this beautiful and strong program!!!
ENGLISH
ZONEMINDER installation procedure
Ubuntu Hardy 8.04 32bit
Kernel 2.6.24-16
8Ch 240fps video pci board
zoneminder 1.23.3
1. Get the new packet type in a terminal
Code:
wget ftp://www.northern-ridge.com.au/zonemin ... 2_i386.deb
wget ftp://www.northern-ridge.com.au/zonemin ... -1_all.deb
2. Installation
Code:
sudo dpkg -i zoneminder_1.23.3-2_i386.deb
sudo dpkg -i libphp-serialization-perl_0.27-1_all.deb
3. ------------ Specific step for kodicom clone 8CH 240fps video pci cards ----------
cd /etc/modprobe.d
make a file with or put the lines below in the file options by tipying in a terminal
sudo gedit /etc/modprobe.d/options
lines:
options i2c_algo_bit bit_test=1
options bttv gbuffers=16 radio=-1 tuner=4 card=102,102,102,102,102,102,102,102
Remember if you don' t see zone minder in the browser http://localhost/zm
4. make this link
cd /etc/apache2/conf.d
ln -s /etc/zm/apache.conf zm.conf
5. edit this file:
/etc/sysctl.conf
and put this lines inside:
kernel.shmall = 134217728
kernel.shmmax = 134217728
6. If you don' t see any image, istead only a black screen type in a teminal:
sudo zmfix -a
(this fix permission problem of zm to video devices )
7. Do a reboot
8. In web configuration of zoneminder
put in the section monitor>source the right height weight
weight (pixels) 320
height (pixels) 240
ITALIAN
1. scaricare questi pacchetti da terminale
Code:
2. Istallarli
Code:
3. ------------ Passo specifico per le schede clone kodicon 8CH 240fps ---------------
cd /etc/modprobe.d
fare un file di testo con nome qualsiasi oppure inserirle nel file options con gedit da root e metterci dentro
lines:
Ricorda se non si vede zoneminder nel browser http://localhost/zm
4. fare questo link
5. editare questo file:
/etc/sysctl.conf
e inserire le seguenti linee :
6. Se non si vede solo uno scermo nero digitare da terminale:
sudo zmfix -a
( questo risolve i permessi di zoneminder sui device video )
7. fare un reboot
8. nella configurazione web di zoneminder
mettere nella sezione monitor>sorgente i seguenti valori
larghezza (pixels) 320
altezza (pixels) 240
Lee Sharp
Post by Lee Sharp »
Some notes.
The lib-serilazation on Peters site is a Hardy version. You only need it for Gutsy.
Your options are for a Kodacom 8 port clone. They will not work for all cards.
You can set "zmfix" guid and not have to manually set the permissions on the video. Otherwise you will have to do it each reboot.
recidivo
Post by recidivo »
Lee Sharp wrote:Some notes.
you right,mine is a kodicom clone card thanks
Lee Sharp
Post by Lee Sharp »
No trouble. Nice writeup... :)
recidivo
Post by recidivo »
can you tell me how can I fix the attribuite with zmfix; I reboot and black screen again .... Thanks
cordel
Post by cordel »
set the suid on zmfix:
chown 4755 zmfix
recidivo
Post by recidivo »
thanks cordel always present !!
craver84
Post by craver84 »
grande recidivo, molto utile!!
sono contento che vi sia anche qualche italiano in questo forum!!!
recidivo
Post by recidivo »
craver84 wrote:grande recidivo, molto utile!!
grazie a te !
english
thanks to you!
now I find the source of my troubles
after
do
sudo zmfix -a !!!!!!!!!
First post updated !
Lee Sharp
Post by Lee Sharp »
Most of this is in the WiKi. However, only in English. If anyone wants to start a translation, that would be fantastic! There is a lot of good information there.
