Correct ffmpeg version
decibel83
Post by decibel83 »
Hi.
I have to install Zoneminder 1.23.3 on a Debian Etch (stable) installation.
What is the correct ffmpeg SVN version I have to install to avoid the libavformat and libavcodec error during the making process of Zoneminder?
And what is the correct configure command to configure and make ffmpeg?
Thank you very much for your help!
Bye.
Lee Sharp
Post by Lee Sharp »
Peter's latest debs have ffmpeg fixed and working. It is not in Debian unstable.
decibel83
Post by decibel83 »
I can't use the .deb version of Zoneminder because it is not available for the amd64 arch...
Lee Sharp
Post by Lee Sharp »
The Debian unstable version works for 64 bit. If you are on Debian, enable the unstable repo, and install it.
PeterHoward
Post by PeterHoward »
decibel83 wrote:I can't use the .deb version of Zoneminder because it is not available for the amd64 arch...
It should be in unstable with ffmpeg support (1.23.3-3) and for amd64.
PJH
