1.24.0 Preview
- zoneminder
- Site Admin
- Contact:
1.24.0 Preview
I have just uploaded the most recent preview version of 1.24.0. You can download it from here.
Lots of minor tweaks and fixes (including security fixes) but the major feature changes are
The main changes in this version, aside from bugfixes and many small changes, are
1) Supports MPEG4 input from cameras. Currently only works with Axis and ACTi cameras but only because those are the only ones I have been able to test.
2) Completely rewritten web GUI. Although it look pretty much the same the file organisation is completely different. Every page is now xHTML and much cleaner with all styling done via CSS. This will also allow support for other custom interfaces (skins) in future.
3) Optional use of mapped memory instead of shared memory.
4) Uses Video for Linux version 2 if present on your system. Monitors can be configured to use version 1 if preferred though.
I do not recommend installing this version over a 1.23.x system yet as the upgrade has not been properly tested. Also there may be multiple bugs and issues. I also recommend installing into a new web directory as nearly all the web files have changed.
Please report issues in this thread only (ie not new threads in the 1.23.x forum) until a dedicated 1.24.0 forum has been set up.
Further details to follow but I am on a train at the mo and about to get into my station!
Phil
- zoneminder
- Site Admin
- Contact:
zoneminder wrote:
So I figured I might as well test it.I do not recommend installing this version over a 1.23.x system yet as the upgrade has not been properly tested.
Upgrading database to version 1.24.0
Loading config from DB
No option 'ZM_OPT_MPEG' found, removing at /usr/share/perl5/site_perl/5.10.0/Zon
eMinder/ConfigAdmin.pm line 1676.
No option 'ZM_PATH_MPEG_ENCODE' found, removing at /usr/share/perl5/site_perl/5.
10.0/ZoneMinder/ConfigAdmin.pm line 1676.
No option 'ZM_WEB_MONTAGE_MAX_COLS' found, removing at /usr/share/perl5/site_per l/5.10.0/ZoneMinder/ConfigAdmin.pm line 1676.
No option 'ZM_WEB_MONTAGE_WIDTH' found, removing at /usr/share/perl5/site_perl/5 .10.0/ZoneMinder/ConfigAdmin.pm line 1676.
No option 'ZM_WEB_MONTAGE_HEIGHT' found, removing at /usr/share/perl5/site_perl/ 5.10.0/ZoneMinder/ConfigAdmin.pm line 1676.
No option 'ZM_WEB_DOUBLE_BUFFER' found, removing at /usr/share/perl5/site_perl/5 .10.0/ZoneMinder/ConfigAdmin.pm line 1676.
No option 'ZM_WEB_FRAMES_PER_LINE' found, removing at /usr/share/perl5/site_perl /5.10.0/ZoneMinder/ConfigAdmin.pm line 1676.
No option 'ZM_WEB_FRAME_LINES' found, removing at /usr/share/perl5/site_perl/5.1 0.0/ZoneMinder/ConfigAdmin.pm line 1676.
No option 'ZM_WEB_DVR_STREAMING' found, removing at /usr/share/perl5/site_perl/5 .10.0/ZoneMinder/ConfigAdmin.pm line 1676.
Saving config to DB
ERROR 1093 (HY000) at line 54: You can't specify target table 'Config' for updat e in FROM clause
Output:
Command 'mysql -hlocalhost -uzmuser -pzmpass zm < /usr/lib/zm/upgrade/zm_update- 1.23.3.sql' exited with status: 1
- zoneminder
- Site Admin
- Contact:
- zoneminder
- Site Admin
- Contact:
The main reason it _may_ be better is that you don't have to fiddle around with sysconfig to allocate the right amounts of space etc, plus you shouldn't get segments left lying around afterwards. Both of these should reduce the number of problems that people get with 'shared memory id' errors and so should reduce the support loadSyRenity wrote:Hi.
Great news with 1 and 2.
Just wondering about 3 (Optional use of mapped memory instead of shared memory) - how's it's better then shared memory?
Phil
- zoneminder
- Site Admin
- Contact:
- zoneminder
- Site Admin
- Contact:
- zoneminder
- Site Admin
- Contact:
- zoneminder
- Site Admin
- Contact:
Link now updated for latest version. Contains fixes for most of todays issues plus some largely untested code for keeping the Notes fields in events up-to-date as the event progresses. So all zones that contributed at any time etc will be listed allowing searches for activity in zones. Previously only the initial zone (or other trigger) was included in the event.
Phil
- zoneminder
- Site Admin
- Contact:
- zoneminder
- Site Admin
- Contact:
- zoneminder
- Site Admin
- Contact:
