1 chip connexant card and no images.....
angelhod
Post by angelhod »
hey
i was using kodicom 4400 for almost 3 years.... but few weeks ago i think
it broke down because all 3 cameras went out....
after few trials i thought that must be something with the card...
so i bought almost the same one.... but with only 1 chip because all i need is 3-4 cams....
so first i've checked it on windows.... and it worked...
then i put it into my slack 12.0.0
changed my modprobe.conf into :
alias char-major-81 bttv
options i2c_algo_bit bit_test=1
options bttv gbuffers=32 card=77 tuner=4 radio=0 coring=1 full_luma_range=1 chroma_agc=1 combfilter=1 autoload=0 triton1=0 vsfx=0
but all i got is the same result as it was with my old card...
all logs are fine... except some errors in apache logs:
[Fri Sep 26 14:35:25 2008] [warn] [client 192.168.2.20] Timeout waiting for output from CGI script /usr/local/apache2/cgi-bin/nph-zms, referer: http://192.168.2.200/zm/index.php?view= ... 0&control=
[Fri Sep 26 14:35:25 2008] [error] [client 192.168.2.20] (70007)The timeout specified has expired: core_output_filter: Error reading from bucket.
[Fri Sep 26 14:35:25 2008] [warn] [client 192.168.2.20] Timeout waiting for output from CGI script /usr/local/apache2/cgi-bin/nph-zms, referer: http://192.168.2.200/zm/index.php?view= ... id=3&mode=
[Fri Sep 26 14:35:25 2008] [warn] [client 192.168.2.20] Timeout waiting for output from CGI script /usr/local/apache2/cgi-bin/nph-zms, referer: http://192.168.2.200/zm/index.php?view= ... id=2&mode=
someone plz help me with it....
angelhod
Post by angelhod »
i must add that i thought that the problem is with my cams or smth.... because i got black screen in connected cams and blue in not connected.... thats why i took one camera.... and a card and put it into windows machine... and it worked there...
angelhod
Post by angelhod »
when tailed my syslog during turning on my cam into monitor mode it showed:
Sep 26 16:58:56 eden zmdc[4819]: WAR [Can't find process with command of 'zma -m 1']
Sep 26 17:01:46 eden zmdc[4819]: WAR [Can't find process with command of 'zma -m 1']
Sep 26 17:01:56 eden zmdc[4819]: WAR [Can't find process with command of 'zmc -d /dev/video0']
Sep 26 17:01:57 eden zmdc[4819]: WAR [Can't find process with command of 'zma -m 1']
angelhod
Post by angelhod »
and zmdc.log:
09/26/08 17:06:56.829419 zmdc[4819].WAR [Can't find process with command of 'zmc -d /dev/video0']
09/26/08 17:06:57.311182 zmdc[4819].INF ['zmc -d /dev/video0' starting at 08/09/26 17:06:57, pid = 5322]
09/26/08 17:06:57.928051 zmdc[4819].WAR [Can't find process with command of 'zma -m 1']
cordel
Post by cordel »
Your apache log suggests that something has changed in your Apache configuration or that nph-zms s no longer available on that path or corrupt.
The rest of the errors suggest that maybe the driver is not being setup so what do you have in dmesg for this card being initialized?
angelhod
Post by angelhod »
thanks for answer Cordel but after i hashed this line
it worked....
but still it is not what i wanted .....
well i thought that the only difference between kodicom 4400
and this one will be : only 4 cameras and 25fps......
but now when i start one monitor..... then add another one and rotate it
the the first one is smashing.....
