zoneminder_1.23.3-3_i386.deb
OK. 1.23.3-3 is now packaged for ubuntu. ftp://ftp.northern-ridge.com.au/zonemin ... 3_i386.deb
The only changes from -2 involve fixing some bugs in the Debian BTS. In terms of functionality it's the same as -2 (which never went into the debian repo).
As per usual, if you're using Debian, get it from unstable, I only provide an Ubuntu package at the above location.
PJH
PJH
First of all... THANK YOU!!! This is GREAT!
second... can someone walk me through the dependancy fix. It seemed fairly simple on the previous post:
Ubuntu 8.04 Server
loaded LAMP and OpenSSH during installation
after installation ran
Code:
sudo apt-get update
sudo apt-get upgrade
downloaded your debfile and ran
Code:
sudo dpkg -i zoneminder_1.23.3-2_i386.deb
got dependency errors and ran
Code:
Not sure what to do here...
sudo apt-get install -f
which resolved dependencies and finished the installation.
After that I ran
Code:
followed by
Code:
sudo /etc/init.d/apache2 reload
last i changed the option ZM_PATH_FFMPEG to /usr/bin/ffmpeg
Done and working
My system didn't seem to install correctly but I'm not sure how to tell other than zm does not seem to be running?
Thanks.
Ubuntu 8.04 Server
Code:
sudo apt-get update
Code:
Code:
After that I ran
Code:
followed by
Code:
Done and working
Thanks.
MRD
OK... the link from the installed apache.conf to the zoneminder.conf seems to make things better, but I still had a ton of scrolling messages about weather to uninstall zoneminder and install other things when I tried the "aptitude install -f" option.
Can anyone shed some light on that process...
Thanks!
Thanks!
MRD
Should that be "apt-get install -f" ? If it's aptitude I don't ever use it so I can't help you there . . for the apt-get option I don't usually see options to uninstall zoneminder . . . but it wouldn't surprise me that much as it's one way of fixing the dependency problemmrd wrote:OK... the link from the installed apache.conf to the zoneminder.conf seems to make things better, but I still had a ton of scrolling messages about weather to uninstall zoneminder and install other things when I tried the "aptitude install -f" option.
Thats a shame... do you have a timescale?PeterHoward wrote:You want the bad news? I can't get it to build with the repo ffmpeg packages . . . which means it may have to be dumbed-down again.Lee Sharp wrote:Cool. And allow me to be the first to say;
When are you releasing 1.24?!?!?
You know it is coming....
PJH
Cheers, TrOjAn
I just took a week off my real job with the following (partial) todo list:TrOjAn wrote:Thats a shame... do you have a timescale?PeterHoward wrote:You want the bad news? I can't get it to build with the repo ffmpeg packages . . . which means it may have to be dumbed-down again.Lee Sharp wrote:Cool. And allow me to be the first to say;
PJH
Cheers, TrOjAn
- 1) Clean reinstall of firewall (IPCop), as it has been having major post-update probs for close to 2 years.
2) A clean ffmpeg-enabled zoneminder release
3) Reinstall main server from ubuntu i386 to ubuntu x86-64 to allow me to easily do 64-bit builds.
4) Get lots done on the Chookhouse which was due for completion in October 2007.
5) Get back to looking at Zoneminder 1.24 (after initial failed builds)
The main problem is, however, I am constrained by what Debian and Ubuntu offer as the packaged version of ffmpeg. There is considerably more scope for experimenting with the build than I've done so far, but the answer may be "wait till Debian updates their ffmpeg package" - which I can make some noises about but I have no idea how much notice would be taken.
PJH
(PS: You never responded on the other thread about your upgrade probs; have you resolved that?)
If you want we have several x64 boxes here that aren't doing anything...I can install x64 on one of them and let you play with it remotely...and you would have local access to RTSP cameras in our office
PeterHoward wrote:I just took a week off my real job with the following (partial) todo list:TrOjAn wrote:Thats a shame... do you have a timescale?PeterHoward wrote: You want the bad news? I can't get it to build with the repo ffmpeg packages . . . which means it may have to be dumbed-down again.
PJH
Cheers, TrOjAnI got 1, 2, and 4 done. 3 will have to go on the back burner for now (I want a clear day to deal with the inevitable fallout of the reinstall). So of my "side projects" 1.24 is bubbling to the top of the list.
PJH
