Posted: Thu Oct 02, 2008 7:53 pm
by RobinQi
To be honest I forgot the model of the card. But here is the result of both commands:
rt@Sun#tmp>cat /proc/interrupts
CPU0
0: 209 IO-APIC-edge timer
1: 10 IO-APIC-edge i8042
3: 2 IO-APIC-edge
4: 2 IO-APIC-edge
6: 5 IO-APIC-edge floppy
7: 0 IO-APIC-edge parport0
8: 1 IO-APIC-edge rtc0
9: 0 IO-APIC-fasteoi acpi
12: 112 IO-APIC-edge i8042
14: 0 IO-APIC-edge ata_piix
15: 39791 IO-APIC-edge ata_piix
16: 1983 IO-APIC-fasteoi bttv3, eth0
17: 11 IO-APIC-fasteoi bttv0, bttv4
18: 124467 IO-APIC-fasteoi aic7xxx, CS46XX, bttv1
19: 124248 IO-APIC-fasteoi uhci_hcd:usb1, firewire_ohci, aic7xxx, bttv2
NMI: 0 Non-maskable interrupts
LOC: 752085 Local timer interrupts
RES: 0 Rescheduling interrupts
CAL: 0 function call interrupts
TLB: 0 TLB shootdowns
TRM: 0 Thermal event interrupts
SPU: 0 Spurious interrupts
ERR: 0
MIS: 0
rt@Sun#tmp>
rt@Sun#tmp>
rt@Sun#tmp>dmesg |grep bttv
bttv: driver version 0.9.17 loaded
bttv: using 8 buffers with 2080k (520 pages) each for capture
bttv: Bt8xx card found (0).
bttv0: Bt878 (rev 17) at 0000:03:05.0, irq: 17, latency: 64, mmio: 0x40120000
bttv0: using: *** UNKNOWN/GENERIC *** [card=0,autodetected]
bttv0: gpio: en=00000000, out=00000000 in=00f360ff [init]
bttv0: tuner type unset
bttv0: i2c: checking for MSP34xx @ 0x80... not found
bttv0: i2c: checking for TDA9875 @ 0xb0... not found
bttv0: i2c: checking for TDA7432 @ 0x8a... not found
bttv0: registered device video0
bttv0: registered device vbi0
bttv: Bt8xx card found (1).
bttv1: Bt878 (rev 17) at 0000:04:08.0, irq: 18, latency: 64, mmio: 0x40000000
bttv1: detected: Provideo PV150A-1 [card=98], PCI subsystem ID is aa00:1460
bttv1: using: ProVideo PV150 [card=98,autodetected]
bttv1: gpio: en=00000000, out=00000000 in=00ffffff [init]
bttv1: tuner absent
bttv1: registered device video1
bttv1: registered device vbi1
bttv1: PLL: 28636363 => 35468950 .. ok
bttv: Bt8xx card found (2).
bttv2: Bt878 (rev 17) at 0000:04:09.0, irq: 19, latency: 64, mmio: 0x40002000
bttv2: detected: Provideo PV150A-2 [card=98], PCI subsystem ID is aa01:1461
bttv2: using: ProVideo PV150 [card=98,autodetected]
bttv2: gpio: en=00000000, out=00000000 in=00ffffff [init]
bttv2: tuner absent
bttv2: registered device video2
bttv2: registered device vbi2
bttv2: PLL: 28636363 => 35468950 .. ok
bttv: Bt8xx card found (3).
bttv3: Bt878 (rev 17) at 0000:04:0a.0, irq: 16, latency: 64, mmio: 0x40004000
bttv3: detected: Provideo PV150A-3 [card=98], PCI subsystem ID is aa02:1462
bttv3: using: ProVideo PV150 [card=98,autodetected]
bttv3: gpio: en=00000000, out=00000000 in=00ffffff [init]
bttv3: tuner absent
bttv3: registered device video3
bttv3: registered device vbi3
bttv3: PLL: 28636363 => 35468950 .. ok
bttv: Bt8xx card found (4).
bttv4: Bt878 (rev 17) at 0000:04:0b.0, irq: 17, latency: 64, mmio: 0x40006000
bttv4: detected: Provideo PV150A-4 [card=98], PCI subsystem ID is aa03:1463
bttv4: using: ProVideo PV150 [card=98,autodetected]
bttv4: gpio: en=00000000, out=00000000 in=00ffffff [init]
bttv4: tuner absent
bttv4: registered device video4
bttv4: registered device vbi4
bttv4: PLL: 28636363 => 35468950 .. ok
bttv1: PLL can sleep, using XTAL (28636363).
bttv2: PLL can sleep, using XTAL (28636363).
bttv1: SCERR @ 2f12f000,bits: HSYNC FBUS SCERR*
bttv2: SCERR @ 2faee000,bits: HSYNC FBUS SCERR*
bttv1: timeout: drop=0 irq=363/364, risc=2f12f000, bits: HSYNC FBUS
bttv2: timeout: drop=0 irq=226/228, risc=2faee01c, bits: HSYNC FBUS
bttv1: timeout: drop=0 irq=439/440, risc=2f12f000, bits: HSYNC FBUS
bttv2: timeout: drop=0 irq=303/305, risc=2faee01c, bits: HSYNC FBUS
bttv2: timeout: drop=0 irq=376/378, risc=2faee000, bits: HSYNC FBUS
bttv1: timeout: drop=0 irq=513/514, risc=2f12f000, bits: HSYNC FBUS
bttv1: timeout: drop=0 irq=685/897, risc=2f12f000, bits: HSYNC FBUS
bttv2: timeout: drop=0 irq=548/550, risc=2faee01c, bits: HSYNC FBUS
bttv1: timeout: drop=0 irq=895/1107, risc=2f12f000, bits: HSYNC FBUS
bttv2: timeout: drop=0 irq=689/692, risc=2faee01c, bits: HSYNC FBUS
bttv1: timeout: drop=0 irq=1035/1247, risc=2f12f000, bits: HSYNC FBUS
bttv2: timeout: drop=0 irq=759/762, risc=2faee01c, bits: HSYNC FBUS
bttv2: timeout: drop=0 irq=13322/13328, risc=2faee000, bits: HSYNC FBUS
bttv1: timeout: drop=0 irq=13676/13888, risc=2f12f01c, bits: HSYNC FBUS
bttv1: timeout: drop=0 irq=16468/16680, risc=2f12f000, bits: HSYNC FBUS
bttv2: timeout: drop=0 irq=59091/59107, risc=2faee000, bits: HSYNC FBUS
bttv1: timeout: drop=0 irq=58674/58886, risc=2f12f01c, bits: HSYNC FBUS
bttv2: timeout: drop=0 irq=59312/59328, risc=2faee000, bits: HSYNC FBUS
bttv1: timeout: drop=0 irq=58971/59183, risc=2f12f01c, bits: HSYNC FBUS
bttv2: timeout: drop=0 irq=59882/59899, risc=2faee000, bits: HSYNC FBUS
bttv1: timeout: drop=0 irq=59618/59830, risc=2f12f01c, bits: HSYNC FBUS
bttv1: timeout: drop=0 irq=59767/59979, risc=2f12f000, bits: HSYNC FBUS
bttv2: timeout: drop=0 irq=59937/59954, risc=2faee000, bits: HSYNC FBUS
bttv1: timeout: drop=0 irq=63063/63275, risc=2f12f000, bits: HSYNC FBUS
bttv1: timeout: drop=0 irq=63269/63481, risc=2f12f000, bits: HSYNC FBUS
bttv2: timeout: drop=0 irq=64410/64428, risc=2faee01c, bits: HSYNC FBUS
bttv1: timeout: drop=0 irq=63799/64011, risc=2f12f000, bits: HSYNC FBUS
bttv2: timeout: drop=0 irq=64871/64889, risc=2faee01c, bits: HSYNC FBUS
bttv1: timeout: drop=0 irq=64008/64220, risc=2f12f000, bits: HSYNC FBUS
bttv2: timeout: drop=0 irq=65009/65028, risc=2faee01c, bits: HSYNC FBUS
bttv1: timeout: drop=0 irq=64176/64388, risc=2f12f000, bits: HSYNC FBUS
bttv2: timeout: drop=0 irq=65108/65127, risc=2faee01c, bits: HSYNC FBUS
bttv1: timeout: drop=0 irq=66606/66818, risc=2f12f000, bits: HSYNC FBUS
bttv2: timeout: drop=0 irq=67471/67490, risc=2faee01c, bits: HSYNC FBUS
bttv1: timeout: drop=0 irq=71175/71387, risc=2f12f01c, bits: HSYNC FBUS
bttv2: timeout: drop=0 irq=71968/71989, risc=2faee01c, bits: HSYNC FBUS
bttv2: timeout: drop=0 irq=72439/72460, risc=2faee000, bits: HSYNC FBUS
bttv1: timeout: drop=0 irq=71724/71936, risc=2f12f01c, bits: HSYNC FBUS
bttv2: timeout: drop=0 irq=72911/72932, risc=2faee000, bits: HSYNC FBUS
bttv1: timeout: drop=0 irq=72272/72484, risc=2f12f01c, bits: HSYNC FBUS
bttv2: timeout: drop=0 irq=73174/73195, risc=2faee000, bits: HSYNC FBUS
bttv1: timeout: drop=0 irq=72610/72822, risc=2f12f01c, bits: HSYNC FBUS
bttv2: timeout: drop=0 irq=73705/73727, risc=2faee000, bits: HSYNC FBUS
bttv1: timeout: drop=0 irq=73218/73430, risc=2f12f01c, bits: HSYNC FBUS
bttv2: timeout: drop=0 irq=74893/74915, risc=2faee000, bits: HSYNC FBUS
bttv1: timeout: drop=0 irq=74483/74695, risc=2f12f01c, bits: HSYNC FBUS
bttv2: timeout: drop=0 irq=75941/75964, risc=2faee000, bits: HSYNC FBUS
bttv1: timeout: drop=0 irq=75607/75819, risc=2f12f01c, bits: HSYNC FBUS
bttv2: timeout: drop=0 irq=75993/76016, risc=2faee000, bits: HSYNC FBUS
bttv1: timeout: drop=0 irq=75733/75945, risc=2f12f01c, bits: HSYNC FBUS
bttv2: timeout: drop=0 irq=76353/76376, risc=2faee000, bits: HSYNC FBUS
bttv1: timeout: drop=0 irq=76170/76382, risc=2f12f01c, bits: HSYNC FBUS
bttv1: timeout: drop=0 irq=77629/77841, risc=2f12f000, bits: HSYNC FBUS
bttv2: timeout: drop=0 irq=77743/77766, risc=2faee01c, bits: HSYNC FBUS
bttv1: timeout: drop=0 irq=77809/78021, risc=2f12f000, bits: HSYNC FBUS
bttv2: timeout: drop=0 irq=77854/77878, risc=2faee01c, bits: HSYNC FBUS
bttv2: timeout: drop=0 irq=89348/89374, risc=2faee000, bits: HSYNC FBUS
bttv1: timeout: drop=0 irq=89377/89589, risc=2f12f01c, bits: HSYNC FBUS
bttv2: timeout: drop=0 irq=89653/89680, risc=2faee000, bits: HSYNC FBUS
bttv1: timeout: drop=0 irq=89758/89970, risc=2f12f01c, bits: HSYNC FBUS
bttv2: timeout: drop=0 irq=99802/99831, risc=2faee000, bits: HSYNC FBUS
bttv1: timeout: drop=0 irq=99981/100193, risc=2f12f01c, bits: HSYNC FBUS
bttv1: timeout: drop=0 irq=124163/124375, risc=2f12f000, bits: HSYNC FBUS
bttv2: timeout: drop=0 irq=123919/123954, risc=2faee000, bits: HSYNC FBUS
bttv1: timeout: drop=0 irq=124204/124416, risc=2f12f000, bits: HSYNC
bttv2: timeout: drop=0 irq=123956/123991, risc=2faee000, bits: HSYNC
bttv1: timeout: drop=0 irq=124240/124452, risc=2f12f000, bits: HSYNC
bttv2: timeout: drop=0 irq=123992/124036, risc=2faee000, bits: HSYNC
bttv2: timeout: drop=0 irq=124034/124080, risc=2faee000, bits: HSYNC
bttv2: timeout: drop=0 irq=124072/124118, risc=2faee000, bits: HSYNC
bttv2: timeout: drop=0 irq=124114/124160, risc=2faee000, bits: HSYNC
bttv2: timeout: drop=0 irq=124149/124196, risc=2faee000, bits: HSYNC
bttv2: timeout: drop=0 irq=124185/124232, risc=2faee000, bits: HSYNC
bttv2: timeout: drop=0 irq=124221/124269, risc=2faee000, bits: HSYNC
bttv2: timeout: drop=0 irq=124256/124305, risc=2faee000, bits: HSYNC
