Page 1 of 1
A lot of resources
Posted: Sat Oct 11, 2008 12:59 am
by MatthewJ
One or 2 cameras is fine, but as i add more my box can't keep up with the required resources.
I have a fresh Debian install solely for ZoneMinder. It's a P4 with 1gb ram, 250gb hdd.
The zma process seems to be using 100mb or memory and 10% cpu.
I am using the mode modetect.
Is there any options i can set to have zoneminder use a little less resources. If not, can you suggest some system requirements i would need for5 cameras.
Thanks.
Posted: Sat Oct 11, 2008 1:47 am
by cordel
Lower the frame rate on each cam.
Posted: Sat Oct 11, 2008 1:50 am
by MatthewJ
would that be the "Image Buffer Size (frames)" option ?
Posted: Sat Oct 11, 2008 3:28 am
by cordel
No Frames Per Second (FPS).
