Mocord with external triggers
Posted: Fri Oct 17, 2008 1:01 pm
Hi all,
I've been using zoneminder for several months now, with 7 monitors (2 analog + 5 ip cameras) set on mocord.
So far I'm extremely satisfied with the results.
Right now I'm capturing at 320x240.
I wanted to raise the resolution on a couple of cameras to 640x480.
Since CPU usage was too much to handle for the computer, I've looked into external triggering of motion. The 5 vivotek ip cameras have built in motion detection.
So I finally could set up the cameras to trigger alarms on zoneminder.
In zoneminder I set up mocord on this cameras and then I deleted all zones.
However, I see that the usage of zma on the monitor with higher resolution is still very high.
I thought I could set the monitor on record, without analysis, letting the camera's motion detection trigger the alarm but the triggers are rejected by zmtrigger.pl if the camera is on record and not on mocord.
so, is there a way to disable zma on this monitor? or a way of using record and having events hilighted by external triggers?
regards,
davide
regards,
davide
