problems with two inputs on generic 1 chip 4 port bt848 card
Posted: Tue Oct 21, 2008 2:15 pm
my current setup holds two cameras on one generic 1 chip 4 port bt848 card. It seemed to work like a charm, but during the last weeks I came across several problems.
If I activate more than one input at the same time the picture seems to get worse - could this be an interlacing issue because of the dropped framerate I get with more inputs on one chip?
The main cam seems to have problems to adjust to the lightning for some unkown reason and therefore the picture sometimes gets periodically lighter or darker. As long as I have just one cam on modect everything works fine but as soon as I activate the second one I get much more false alarms than before. Could this also be a result of the dropped framerate? My guess is that the lower framerate results in a greater difference between single images.
Right now I am considering to buy two additionional cards of the same kind (aiming at three cams) but I wanted to ask if there is a good chance that this could really solve my problems.
