hello everybody!
Hope this was not a FAQ..anyway:
I have 1 client (gentoo,kde), 1 server (gentoo, no X)
when I enter http://myServerIP/zoneminder/index.php and click on the name of the monitor just created, the video box says "no video" and the status is "inactive". Why?
My card has 4 connectors so I tried them all with no result.
I guess that additional infos should be provided, but please let me know which ones, I prefere not to post tons of useless parameters.
bye, Stefano.
My logs (last lines):
zmdc:
10/28/08 14:34:58.481599 zmdc[20521].INF ['zmc -d /dev/video0' starting at 08/10/28 14:34:58, pid = 21453]
10/28/08 14:34:58.621460 zmdc[20521].ERR ['zmc -d /dev/video0' exited abnormally, exit status 255]
10/28/08 14:35:09.782740 zmdc[20521].INF ['zmc -d /dev/video0' starting at 08/10/28 14:35:09, pid = 21457]
10/28/08 14:35:09.920963 zmdc[20521].ERR ['zmc -d /dev/video0' exited abnormally, exit status 255]
10/28/08 14:35:21.083872 zmdc[20521].INF ['zmc -d /dev/video0' starting at 08/10/28 14:35:21, pid = 21461]
10/28/08 14:35:21.222702 zmdc[20521].ERR ['zmc -d /dev/video0' exited abnormally, exit status 255]
zmwatch:
10/28/08 14:36:50.214746 zmwatch[20553].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
10/28/08 14:36:50.216723 zmwatch[20553].INF [Restarting capture daemon for Nuovo, shared memory not valid]
10/28/08 14:36:51.503645 zmwatch[20553].INF ['zmc -d /dev/video0' starting at 08/10/28 14:36:51, pid = 21501]
10/28/08 14:37:01.511894 zmwatch[20553].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
10/28/08 14:37:01.513879 zmwatch[20553].INF [Restarting capture daemon for Nuovo, shared memory not valid]
10/28/08 14:37:02.805567 zmwatch[20553].INF ['zmc -d /dev/video0' starting at 08/10/28 14:37:02, pid = 21505]
10/28/08 14:37:12.813014 zmwatch[20553].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
10/28/08 14:37:12.814996 zmwatch[20553].INF [Restarting capture daemon for Nuovo, shared memory not valid]
10/28/08 14:37:14.110712 zmwatch[20553].INF ['zmc -d /dev/video0' starting at 08/10/28 14:37:14, pid = 21509]
the output of
# zmu -q -d /dev/video0 -v
is
Video Capabilities
Type: 1
Can capture
Video Channels: 1
Audio Channels: 0
Maximum Width: 1024
Maximum Height: 768
Minimum Width: 48
Minimum Height: 32
Window Attributes
X Offset: 0
Y Offset: 0
Width: 640
Height: 480
Picture Attributes
Palette: 8 - YUYV
Colour Depth: 16
Brightness: 32639
Hue: 32896
Colour :32639
Contrast: 4112
Whiteness: 0
Channel 0 Attributes
Channel: 0
Flags: 0
Type: 2 - Camera
Format: 1 - NTSC
settings on server - no X
Seems you may have one of "those" cards that aren't particularly well documented.
Here's what I dug up with a quick google search. http://lists.zerezo.com/video4linux/msg13322.html
If you can get it working with v4l and displaying properly with xawtv (or something similar) it should work fine with zoneminder. Bottom line, get the card working and proven to work and then tackle zoneminder.
no image
I think I'm with the same problem because the ZM doesn't show no image.
The message log says:
Jan 23 14:44:46 localhost zmwatch[4797]: INF [Restarting capture daemon for New, time since last capture 9 seconds (1232729086-1232729077)]
Jan 23 14:44:46 localhost zmdc[11735]: INF ['zmc -d /dev/video0' started at 09/01/23 14:44:46]
Jan 23 14:44:46 localhost zmc_dvideo0[11735]: INF [Debug Level = 0, Debug Log = <none>]
Jan 23 14:44:46 localhost zmdc[4748]: INF ['zmc -d /dev/video0' starting at 09/01/23 14:44:46, pid = 11735]
Jan 23 14:44:46 localhost zmwatch[4797]: INF ['zmc -d /dev/video0' starting at 09/01/23 14:44:46, pid = 11735]
Jan 23 14:44:46 localhost zmc_dvideo0[11735]: INF [Starting Capture]
Jan 23 14:44:47 localhost zmc_dvideo0[11735]: ERR [Sync failure for frame 1 buffer 2(1): Invalid argument]
Jan 23 14:44:47 localhost zmc_dvideo0[11735]: ERR [Failed to post-capture monitor 0]
Jan 23 14:44:47 localhost zmdc[4748]: ERR ['zmc -d /dev/video0' exited abnormally, exit status 255]
The camera is working fine with xawtv, vlc and cheese.
The command zmu -q -d /dev/video0 -v shows:
Video Capabilities
Name: USB Camera (041e:4051)
Type: 1
Can capture
Video Channels: 1
Audio Channels: 0
Maximum Width: 640
Maximum Height: 480
Minimum Width: 48
Minimum Height: 32
Window Attributes
X Offset: 0
Y Offset: 0
Width: 320
Height: 240
Picture Attributes
Palette: 0 - Unknown
Colour Depth: 8
Brightness: 32896
Hue: 0
Colour :0
Contrast: 32768
Whiteness: 26214
Channel: 0
Flags: 0
Type: 2 - Camera
Format: 0 - PAL
Maybe it is useful for someone helping me.
Video Capabilities
Type: 1
Can capture
Video Channels: 1
Audio Channels: 0
Maximum Width: 640
Maximum Height: 480
Minimum Width: 48
Minimum Height: 32
Window Attributes
X Offset: 0
Y Offset: 0
Width: 320
Height: 240
Picture Attributes
Colour Depth: 8
Brightness: 32896
Hue: 0
Colour :0
Contrast: 32768
Whiteness: 26214
Channel: 0
Flags: 0
Type: 2 - Camera
Format: 0 - PAL
no image
ok, but the command v4l-info shows this:
### v4l2 device info [/dev/video0] ###
general info
VIDIOC_QUERYCAP
driver : "zc3xx"
card : "USB Camera (041e:4051)"
bus_info : "0000:00:1d.0"
version : 2.2.0
capabilities : 0x5000001 [VIDEO_CAPTURE,READWRITE,STREAMING]
standards
inputs
VIDIOC_ENUMINPUT(0)
index : 0
type : CAMERA
audioset : 0
tuner : 0
std : 0x0 []
status : 0x0 []
video capture
VIDIOC_ENUM_FMT(0,VIDEO_CAPTURE)
index : 0
type : VIDEO_CAPTURE
flags : 1
description : "JPEG"
pixelformat : 0x4745504a [JPEG]
VIDIOC_G_FMT(VIDEO_CAPTURE)
fmt.pix.width : 320
fmt.pix.height : 240
fmt.pix.pixelformat : 0x4745504a [JPEG]
fmt.pix.field : NONE
fmt.pix.bytesperline : 320
fmt.pix.sizeimage : 29390
fmt.pix.colorspace : JPEG
fmt.pix.priv : 1
controls
VIDIOC_QUERYCTRL(BASE+0)
type : INTEGER
minimum : 0
maximum : 255
step : 1
default_value : 128
flags : 0
VIDIOC_QUERYCTRL(BASE+1)
type : INTEGER
minimum : 0
maximum : 256
step : 1
default_value : 128
flags : 0
### video4linux device info [/dev/video0] ###
general info
VIDIOCGCAP
name : "USB Camera (041e:4051)"
type : 0x1 [CAPTURE]
channels : 1
audios : 0
maxwidth : 640
maxheight : 480
minwidth : 48
minheight : 32
channels
VIDIOCGCHAN(0)
channel : 0
tuners : 0
flags : 0x0 []
type : CAMERA
norm : 0
tuner
ioctl VIDIOCGTUNER: Invalid argument
audio
ioctl VIDIOCGAUDIO: Invalid argument
VIDIOCGPICT
brightness : 32896
hue : 0
colour : 0
contrast : 32768
whiteness : 26214
depth : 8
palette : unknown
buffer
ioctl VIDIOCGFBUF: Invalid argument
window
VIDIOCGWIN
x : 0
y : 0
width : 320
height : 240
chromakey : 0
flags : 0
This way, with what I know, the v4l is recognizing the camera. Isn't it?
general info
VIDIOC_QUERYCAP
driver : "zc3xx"
version : 2.2.0
standards
inputs
VIDIOC_ENUMINPUT(0)
index : 0
type : CAMERA
audioset : 0
tuner : 0
std : 0x0 []
status : 0x0 []
video capture
index : 0
flags : 1
fmt.pix.width : 320
fmt.pix.priv : 1
controls
type : INTEGER
minimum : 0
maximum : 255
step : 1
default_value : 128
flags : 0
type : INTEGER
minimum : 0
maximum : 256
step : 1
default_value : 128
flags : 0
general info
VIDIOCGCAP
channels : 1
audios : 0
maxwidth : 640
maxheight : 480
minwidth : 48
minheight : 32
channels
VIDIOCGCHAN(0)
channel : 0
tuners : 0
flags : 0x0 []
type : CAMERA
norm : 0
tuner
audio
VIDIOCGPICT
brightness : 32896
hue : 0
colour : 0
contrast : 32768
whiteness : 26214
depth : 8
palette : unknown
buffer
window
VIDIOCGWIN
x : 0
y : 0
width : 320
height : 240
chromakey : 0
flags : 0
