rotate left in orientation for remote cameras doesn't work
bainssu
Post by bainssu »
I have a few remote cameras ...one of them is mounted on it's side and needs rotate left to display the image the correct way up. However setting rotate left causes the image that is returned to be incorrect ...
on 1.23.1
set source> Orientation> rotate left and save
image that is now displayed is bad.
S
zoneminder
Site Admin
Post by zoneminder »
Thanks. I will check this.
I assume you have changed your monitor dimensions to reflect the rotation? Ie 240x320 rather then 320x240 for example.
Phil
bainssu
Post by bainssu »
thanks that's done the trick..!
S
