I have installed ZoneMinder v1.23.3 on Mandriva 2008.0. My camera is a Trendnet TV-IP100 network camera and no password is set so it doesn't require authentication. Zoneminder appears to run properly when accessed at http://127.0.0.1/zm/ through Firefox.
I entered the camera's IP address, and set "Remote Host Path" to "/VIDEO.CGI". In Options/Network I checked the box for "Are you going to use remote/networked cameras (?)". I still get no video image whatsoever in ZoneMinder, even through Firefos can access the camera's image just fine.
A Wireshark packet capture shows packets on the network when accessing the TV-IP100 from Firefox, but ZoneMinder is not putting any packets on the network.
What might be wrong with my installation?
No packets sent to IP camera
whats in your logs?
James Wilson
I found two log files that may hold the clue to solving this problem. Here are excerpts from each file.
zmwatch.log
zmdc.log
zmwatch.log
11/13/2008 11:23:24.154042 zmwatch[7609].INF ['zmc -m 2' starting at 08/11/13 11:23:24, pid = 8018]
11/13/2008 11:23:34.156434 zmwatch[7609].ERR [Can't get shared memory id '7a6d0002', 2: No such file or directory]
11/13/2008 11:23:34.157023 zmwatch[7609].INF [Restarting capture daemon for TV-IP100, shared memory not valid]
11/13/2008 11:23:34.465628 zmwatch[7609].INF ['zmc -m 2' starting at 08/11/13 11:23:34, pid = 8032]
11/13/2008 11:23:44.468001 zmwatch[7609].ERR [Can't get shared memory id '7a6d0002', 2: No such file or directory]
11/13/2008 11:23:44.468583 zmwatch[7609].INF [Restarting capture daemon for TV-IP100, shared memory not valid]
11/13/2008 11:23:44.751244 zmwatch[7609].INF ['zmc -m 2' starting at 08/11/13 11:23:44, pid = 8037]
11/13/2008 11:23:54.753656 zmwatch[7609].ERR [Can't get shared memory id '7a6d0002', 2: No such file or directory]
11/13/2008 11:23:54.754209 zmwatch[7609].INF [Restarting capture daemon for TV-IP100, shared memory not valid]
11/13/2008 11:23:55.022067 zmwatch[7609].INF ['zmc -m 2' starting at 08/11/13 11:23:55, pid = 8042]
11/13/2008 11:23:13.850520 zmdc[7566].INF ['zmc -m 2' starting at 08/11/13 11:23:13, pid = 8008]
11/13/2008 11:23:13.883419 zmdc[7566].ERR ['zmc -m 2' exited abnormally, exit status 255]
11/13/2008 11:23:24.149109 zmdc[7566].INF ['zmc -m 2' starting at 08/11/13 11:23:24, pid = 8018]
11/13/2008 11:23:24.171251 zmdc[7566].ERR ['zmc -m 2' exited abnormally, exit status 255]
11/13/2008 11:23:34.460561 zmdc[7566].INF ['zmc -m 2' starting at 08/11/13 11:23:34, pid = 8032]
11/13/2008 11:23:34.489627 zmdc[7566].ERR ['zmc -m 2' exited abnormally, exit status 255]
11/13/2008 11:23:44.744672 zmdc[7566].INF ['zmc -m 2' starting at 08/11/13 11:23:44, pid = 8037]
11/13/2008 11:23:44.776147 zmdc[7566].ERR ['zmc -m 2' exited abnormally, exit status 255]
11/13/2008 11:23:55.016961 zmdc[7566].INF ['zmc -m 2' starting at 08/11/13 11:23:55, pid = 8042]
11/13/2008 11:23:55.043897 zmdc[7566].ERR ['zmc -m 2' exited abnormally, exit status 255]
