Deleting events
Posted: Mon Nov 17, 2008 11:10 pm
What is the proper way to remove events?
After I remove events (using browser and http://ip/zm), I see error in my log file.
Nov 17 17:04:39 localhost zmaudit[11035]: INF [deleting]
Nov 17 17:04:39 localhost zmaudit[11035]: INF [Found orphaned statistic records for event '1572']
Nov 17 17:04:39 localhost zmaudit[11035]: INF [Found orphaned statistic records for event '1573']
Nov 17 17:04:39 localhost zms[10572]: ERR [Can't open /var/www/html/zm/events/8/1364/077-capture.jpg: No such file or directory]
Nov 17 17:04:39 localhost zmaudit[11035]: INF [Found orphaned statistic records for event '1574']
Nov 17 17:05:38 localhost zms[10593]: ERR [Can't open /var/www/html/zm/events/8/1181/031-capture.jpg: No such file or directory]
Nov 17 17:05:38 localhost zms[10587]: ERR [Can't open /var/www/html/zm/events/8/1184/167-capture.jpg: No such file or directory]
Nov 17 17:05:39 localhost zms[10579]: ERR [Can't open /var/www/html/zm/events/8/1188/027-capture.jpg: No such file or directory]
Nov 17 17:05:39 localhost zms[10581]: ERR [Can't open /var/www/html/zm/events/8/1187/028-capture.jpg: No such file or directory]
Nov 17 17:05:39 localhost zms[10572]: ERR [Can't open /var/www/html/zm/events/8/1364/077-capture.jpg: No such file or directory]
Nov 17 17:05:40 localhost zms[10583]: ERR [Can't open /var/www/html/zm/events/8/1186/028-capture.jpg: No such file or directory]
Thanks in adv
Paras.
Thanks in adv
Paras.
