Wrong palette with V4L2
Ciaccia
Post by Ciaccia »
Hi all,
Yesterday I downloaded/compiled the last ZoneMinder version (ZoneMinder-1.24.0-rc1-2678.tar.gz) since I wanted to try the support for the V4L(2) webcams.
After I compiled/installed everything, the webcam was recognized, but its colors were always pink/bluish. I tried all the possible palettes, but none of them displayed the colors correctly.
With the YUYV palette configured in Zoneminder I get the following picture:
Using ffmpeg streaming through v4l2 I get the same picture but with right colors:
This is the output of v4l-info on my PC:
### v4l2 device info [/dev/video0] ###
general info
    VIDIOC_QUERYCAP
        driver                  : "uvcvideo"
        card                    : "UVC Camera (046d:08ca)"
        bus_info                : "0000:02:00.2"
        version                 : 0.1.0
        capabilities            : 0x4000001 [VIDEO_CAPTURE,STREAMING]
standards
inputs
    VIDIOC_ENUMINPUT(0)
        index                   : 0
        type                    : CAMERA
        audioset                : 0
        tuner                   : 0
        std                     : 0x0 []
        status                  : 0x0 []
video capture
    VIDIOC_ENUM_FMT(0,VIDEO_CAPTURE)
        index                   : 0
        type                    : VIDEO_CAPTURE
        flags                   : 1
        description             : "MJPEG"
        pixelformat             : 0x47504a4d [MJPG]
    VIDIOC_ENUM_FMT(1,VIDEO_CAPTURE)
        index                   : 1
        flags                   : 0
        description             : "YUV 4:2:2 (YUYV)"
        pixelformat             : 0x56595559 [YUYV]
    VIDIOC_G_FMT(VIDEO_CAPTURE)
        fmt.pix.width           : 640
        fmt.pix.height          : 480
        fmt.pix.pixelformat     : 0x56595559 [YUYV]
        fmt.pix.field           : NONE
        fmt.pix.bytesperline    : 1280
        fmt.pix.sizeimage       : 614400
        fmt.pix.colorspace      : SRGB
        fmt.pix.priv            : 0
controls
    VIDIOC_QUERYCTRL(BASE+0)
        type                    : INTEGER
        minimum                 : 0
        maximum                 : 255
        step                    : 1
        default_value           : 127
        flags                   : 0
    VIDIOC_QUERYCTRL(BASE+1)
        type                    : INTEGER
        minimum                 : 0
        maximum                 : 255
        step                    : 1
        default_value           : 32
        flags                   : 0
    VIDIOC_QUERYCTRL(BASE+2)
        type                    : INTEGER
        minimum                 : 0
        maximum                 : 255
        step                    : 1
        default_value           : 28
        flags                   : 0
### video4linux device info [/dev/video0] ###
general info
    VIDIOCGCAP
        name                    : "UVC Camera (046d:08ca)"
        type                    : 0x1 [CAPTURE]
        channels                : 1
        audios                  : 0
        maxwidth                : 0
        maxheight               : 0
        minwidth                : 48
        minheight               : 32
channels
ioctl VIDIOCGCHAN: Invalid argument
tuner
ioctl VIDIOCGTUNER: Invalid argument
audio
ioctl VIDIOCGAUDIO: Invalid argument
    VIDIOCGPICT
        brightness              : 32639
        hue                     : 0
        colour                  : 8224
        contrast                : 8224
        whiteness               : 0
        depth                   : 16
        palette                 : YUYV
buffer
ioctl VIDIOCGFBUF: Invalid argument
window
    VIDIOCGWIN
        x                       : 0
        y                       : 0
        width                   : 640
        height                  : 480
        chromakey               : 0
        flags                   : 0
Do you think it's a problem with the 1.24.0-rc1 or something related to my configuration?
Thanks a lot for your help
Andrea
yogev_ezra
Post by yogev_ezra »
Hi everyone,
I have Logitech Quickcam Orbit/Sphere 1.3MP and installed ZoneMinder 1.24 build 2679 (ZoneMinder-1.24.0-rc1-2679.tar.gz) on CentOS 5.2.
After overcoming all compile problems (ZoneMinder did not want to compile because of missing ffmpeg packages since default ffmpeg installation did not add them - solved by looking at those forums) - I experience the same problem as described in the above post (the image from V4L2 camera is wrong palette). In addition, the CPU load while I monitor this webcam jumps considerably - a process called "nph-zms" consumes up to 50-70% of the CPU.
Has anyone been able to solve this wrong palette problem? The high CPU load is also an issue for me since I try to build a surveillance system based on a small PC with performance close to thin client. I need to use it with 3 cameras and if this is what happens with one camera, the load for 3 cameras will be probably at 100%. I doubt that I am doing everything correctly, since I heard of people who were able to run ZoneMinder on OpenWRT-based routers, which can offer about 1/2 or 1/3 of the performance of my small PC.
So after this long explanation, here are my specifications:
Hardware
Computer - Fit-PC Slim http://www.fit-pc.com. CPU: AMD Geode LX 800 - 500 MHz. RAM - 512MB. Hard disk - 2.5" SSD IDE Transcend MLC (TS32GSSD25-M)
Camera - Logitech Quickcam Orbit/Sphere 1.3MP (2006 version)
Software
OS - CentOS 5.2 text-only support (no GUI). It was a bit tricky to install CentOS 5.2 on this PC since it does not install there on itself. Anaconda (CentOS installer) thinks that this CPU is not able to execute i686 instructions, so it crashes during installation. On the other hand, there is a workaround by plugging the hard disk of this PC into a PIII laptop, installing CentOS 5.2 there, and then moving the hard disk back to Fit-PC. This also worked for me. The reason I chose CentOS is because I am most familiar with RedHat Enterprise Linux, and CentOS is the free version of RedHat. In addition, ZoneMinder itself was written under CentOS as I understood, so I tried to make the system as similar as possible to the original, to make my life easier with problems solution.
CentOS 4.7 installation is working perfect without any workaround to move the hard disk, but unfortunately Linux-UVC drivers do not compile and do not work under it (at least for me).
Drivers - the linux-uvc driver from CentOS "Atrpms" repository. I tried to compile the linux-uvc driver from their Subversion repository, but did not succeed, so I had to use this RPM.
ZoneMinder - as written above, ZoneMinder-1.24.0-rc1-2679.tar.gz
I also installed a few other UVC streaming helpers like luvcview, mjpeg_streamer etc., to test the camera there, since at the beginning I did not manage to get any output from ZoneMinder at all (not even wrong palette one).
So the outputs from various commands:
[root@localhost tmp]# cat /proc/cpuinfo
processor       : 0
vendor_id       : AuthenticAMD
cpu family      : 5
model           : 10
model name      : Geode(TM) Integrated Processor by AMD PCS
stepping        : 2
cpu MHz         : 499.923
cache size      : 128 KB
fdiv_bug        : no
hlt_bug         : no
f00f_bug        : no
coma_bug        : no
fpu             : yes
fpu_exception   : yes
cpuid level     : 1
wp              : yes
flags           : fpu de pse tsc msr cx8 pge cmov clflush mmx mmxext 3dnowext 3dnow up
bogomips        : 1000.94
[root@localhost tmp]# cat /proc/meminfo
MemTotal:       495124 kB
MemFree:         15636 kB
Buffers:        118504 kB
Cached:         190352 kB
SwapCached:          0 kB
Active:         229084 kB
Inactive:       205004 kB
HighTotal:           0 kB
HighFree:            0 kB
LowTotal:       495124 kB
LowFree:         15636 kB
SwapTotal:     1048568 kB
SwapFree:      1048568 kB
Dirty:              64 kB
Writeback:           0 kB
AnonPages:      125228 kB
Mapped:          15240 kB
Slab:            33096 kB
PageTables:       8380 kB
NFS_Unstable:        0 kB
Bounce:              0 kB
CommitLimit:   1296128 kB
Committed_AS:   824416 kB
VmallocTotal:   524280 kB
VmallocUsed:      3092 kB
VmallocChunk:   520864 kB
HugePages_Total:     0
HugePages_Free:      0
HugePages_Rsvd:      0
Hugepagesize:     4096 kB
[root@localhost tmp]# df -h
Filesystem            Size  Used Avail Use% Mounted on
/dev/mapper/VolGroup00-LogVol00
                       28G  2.6G   24G  10% /
/dev/hda1              97M   18M   74M  20% /boot
tmpfs                 242M     0  242M   0% /dev/shm
[root@localhost tmp]# lspci
00:01.0 Host bridge: Advanced Micro Devices [AMD] CS5536 [Geode companion] Host Bridge (rev 33)
00:01.1 VGA compatible controller: Advanced Micro Devices [AMD] Geode LX Video
00:01.2 Entertainment encryption device: Advanced Micro Devices [AMD] Geode LX AES Security Block
00:0d.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL-8139/8139C/8139C+ (rev 10)
00:0f.0 ISA bridge: Advanced Micro Devices [AMD] CS5536 [Geode companion] ISA (rev 03)
00:0f.2 IDE interface: Advanced Micro Devices [AMD] CS5536 [Geode companion] IDE (rev 01)
00:0f.3 Multimedia audio controller: Advanced Micro Devices [AMD] CS5536 [Geode companion] Audio (rev 01)
00:0f.4 USB Controller: Advanced Micro Devices [AMD] CS5536 [Geode companion] OHC (rev 02)
00:0f.5 USB Controller: Advanced Micro Devices [AMD] CS5536 [Geode companion] EHC (rev 02)
[root@localhost tmp]# lsusb
Bus 001 Device 004: ID 046d:08cc Logitech, Inc. Mic (PTZ)
Bus 001 Device 001: ID 0000:0000
Bus 001 Device 003: ID 18e8:6238 Qcom
Bus 002 Device 001: ID 0000:0000
[root@localhost tmp]# v4l-info
general info
    VIDIOC_QUERYCAP
        driver                  : "uvcvideo"
        card                    : LйLйбKхTю/хTю"
        bus_info                : "0000:00:0f.5"
        version                 : 0.1.0
standards
inputs
    VIDIOC_ENUMINPUT(0)
        index                   : 0
        type                    : CAMERA
        audioset                : 0
        tuner                   : 0
        std                     : 0x0 []
        status                  : 0x0 []
video capture
        index                   : 0
        flags                   : 1
        index                   : 1
        flags                   : 0
        fmt.pix.width           : 320
        fmt.pix.height          : 240
        fmt.pix.pixelformat     : 0x47504a4d [MJPG]
        fmt.pix.bytesperline    : 0
        fmt.pix.sizeimage       : 102400
        fmt.pix.priv            : 0
controls
        type                    : INTEGER
        minimum                 : 0
        maximum                 : 255
        step                    : 1
        default_value           : 127
        flags                   : 0
        type                    : INTEGER
        minimum                 : 0
        maximum                 : 255
        step                    : 1
        default_value           : 32
        flags                   : 0
        type                    : INTEGER
        minimum                 : 0
        maximum                 : 255
        step                    : 1
        default_value           : 28
        flags                   : 0
general info
    VIDIOCGCAP
        channels                : 1
        audios                  : 0
        maxwidth                : 960
        maxheight               : 720
        minwidth                : 48
        minheight               : 32
channels
tuner
audio
    VIDIOCGPICT
        brightness              : 32639
        hue                     : 0
        colour                  : 7196
        contrast                : 8224
        whiteness               : 0
        depth                   : 0
        palette                 : unknown
buffer
window
    VIDIOCGWIN
        x                       : 0
        y                       : 0
        width                   : 320
        height                  : 240
        chromakey               : 0
        flags                   : 0
Output of "top" with ZoneMinder service up but camera not connected:
top - 16:08:25 up 1 day, 17:34,  1 user,  load average: 0.34, 0.16, 0.05
Tasks: 211 total,   1 running, 210 sleeping,   0 stopped,   0 zombie
Cpu(s):  1.6%us,  1.3%sy,  0.0%ni, 95.8%id,  1.3%wa,  0.0%hi,  0.0%si,  0.0%st
Mem:    495124k total,   470632k used,    24492k free,   114580k buffers
Swap:  1048568k total,        0k used,  1048568k free,   190004k cached
  PID USER      PR  NI  VIRT  RES  SHR S %CPU %MEM    TIME+  COMMAND
11917 root      15   0  2324 1080  796 R  1.6  0.2   0:00.15 top
11913 root      15   0  8628 2600 2096 S  0.7  0.5   0:00.22 sshd
 1777 root      16   0  1720  568  476 S  0.3  0.1   0:02.20 syslogd
 2023 mysql     15   0  138m  20m 4636 S  0.3  4.2   4:01.60 mysqld
    1 root      15   0  2064  620  532 S  0.0  0.1   0:02.12 init
    2 root      RT  -5     0    0    0 S  0.0  0.0   0:00.00 migration/0
    3 root      38  19     0    0    0 S  0.0  0.0   0:00.00 ksoftirqd/0
    4 root      RT  -5     0    0    0 S  0.0  0.0   0:00.00 watchdog/0
    5 root      10  -5     0    0    0 S  0.0  0.0   0:00.01 events/0
    6 root      17  -5     0    0    0 S  0.0  0.0   0:00.00 khelper
    7 root      10  -5     0    0    0 S  0.0  0.0   0:00.00 kthread
   10 root      10  -5     0    0    0 S  0.0  0.0   0:00.13 kblockd/0
   11 root      20  -5     0    0    0 S  0.0  0.0   0:00.00 kacpid
   55 root      20  -5     0    0    0 S  0.0  0.0   0:00.00 cqueue/0
   58 root      10  -5     0    0    0 S  0.0  0.0   0:00.01 khubd
   60 root      17  -5     0    0    0 S  0.0  0.0   0:00.05 kseriod
  122 root      25   0     0    0    0 S  0.0  0.0   0:00.00 pdflush
Output of "top" with camera connected and set to 15fps:
top - 16:38:56 up 1 day, 18:04,  1 user,  load average: 1.90, 0.90, 0.42
Tasks: 226 total,   5 running, 221 sleeping,   0 stopped,   0 zombie
Cpu(s): 91.9%us,  2.3%sy,  0.0%ni,  2.3%id,  0.7%wa,  2.9%hi,  0.0%si,  0.0%st
Mem:    495124k total,   487892k used,     7232k free,   115980k buffers
Swap:  1048568k total,        0k used,  1048568k free,   131472k cached
12865 apache    16   0  149m  18m  11m R 32.3  3.8   0:09.90 nph-zms
12873 apache    15   0  149m  18m  11m S 31.4  3.8   0:07.90 nph-zms
12833 apache    16   0  144m  13m  12m R 16.2  2.8   0:12.09 zmc
12880 root      15   0  8632 2604 2096 S  5.3  0.5   0:00.24 sshd
12671 root      15   0  2324 1092  796 R  1.8  0.2   0:04.78 top
  320 root      10  -5     0    0    0 S  0.3  0.0   0:07.16 kjournald
12722 apache    15   0 23360 7240 2792 S  0.3  1.5   0:00.55 httpd
    1 root      15   0  2064  620  532 S  0.0  0.1   0:02.15 init
    3 root      34  19     0    0    0 S  0.0  0.0   0:00.00 ksoftirqd/0
   10 root      10  -5     0    0    0 S  0.0  0.0   0:00.15 kblockd/0
yogev_ezra
Some more outputs - did not want to make the previous post too long:
Last lines from /var/log/messages when I plug the camera into USB connector on my PC:
Dec  6 16:50:37 localhost kernel: usb 1-2: new high speed USB device using ehci_hcd and address 5
Dec  6 16:50:37 localhost kernel: usb 1-2: configuration #1 chosen from 1 choice
Dec  6 16:50:37 localhost kernel: uvcvideo: Found UVC 1.00 device <unnamed> (046d:08cc)
Dec  6 16:50:37 localhost kernel: videodev: "" has no release callback. Please fix your driver for proper sysfs support, see http://lwn.net/Articles/36850/
Dec  6 16:50:37 localhost kernel: input: UVC Camera (046d:08cc) as /class/input/input5
Verbose lsusb output:
[root@localhost tmp]# lsusb -vd 046d:08cc
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass          239 Miscellaneous Device
  bDeviceSubClass         2 ?
  bDeviceProtocol         1 Interface Association
  bMaxPacketSize0        64
  idVendor           0x046d Logitech, Inc.
  idProduct          0x08cc Mic (PTZ)
  bcdDevice            0.05
  iManufacturer           0
  iProduct                0
  iSerial                 2 438F2CA5
  bNumConfigurations      1
  Configuration Descriptor:
    bLength                 9
    bDescriptorType         2
    wTotalLength         1417
    bNumInterfaces          4
    bConfigurationValue     1
    iConfiguration          0
    bmAttributes         0x80
    MaxPower              500mA
    UNRECOGNIZED:  08 0b 00 02 0e 03 00 00
    Interface Descriptor:
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceClass        14 Video
      bInterfaceSubClass      1 Video Control
      bInterfaceProtocol      0
      iInterface              0
      UNRECOGNIZED:  20 41 01 0c 82 06 61 63 70 50 ab 49 b8 cc b3 85 5e 8d 22 50 13 01 04 03 fe ff 0f 00 00 00 00 00
      UNRECOGNIZED:  20 41 01 08 82 06 61 63 70 50 ab 49 b8 cc b3 85 5e 8d 22 51 03 01 04 03 19 00 00 00 00 00 01 00
      UNRECOGNIZED:  22 41 01 0a 82 06 61 63 70 50 ab 49 b8 cc b3 85 5e 8d 22 52 20 01 04 04 ff ff ff ff 00 00 00 00 01 00
      UNRECOGNIZED:  20 41 01 0b 82 06 61 63 70 50 ab 49 b8 cc b3 85 5e 8d 22 55 01 01 04 03 01 00 00 00 00 00 00 00
      UNRECOGNIZED:  20 41 01 09 82 06 61 63 70 50 ab 49 b8 cc b3 85 5e 8d 22 56 02 01 04 03 03 00 00 00 00 00 00 00
      Endpoint Descriptor:
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x87  EP 7 IN
        bmAttributes            3
          Transfer Type            Interrupt
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0010  1x 16 bytes
        bInterval               8
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       0
      bNumEndpoints           0
      bInterfaceSubClass      2 Video Streaming
      iInterface              0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       1
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x81  EP 1 IN
        bmAttributes            5
          Transfer Type            Isochronous
          Synch Type               Asynchronous
          Usage Type               Data
        wMaxPacketSize     0x00c0  1x 192 bytes
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       2
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        wMaxPacketSize     0x0180  1x 384 bytes
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       3
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        wMaxPacketSize     0x0200  1x 512 bytes
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       4
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        wMaxPacketSize     0x0280  1x 640 bytes
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       5
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        wMaxPacketSize     0x0320  1x 800 bytes
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       6
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        wMaxPacketSize     0x03b0  1x 944 bytes
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       7
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        wMaxPacketSize     0x0a80  2x 640 bytes
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       8
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        wMaxPacketSize     0x0b20  2x 800 bytes
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       9
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        wMaxPacketSize     0x0be0  2x 992 bytes
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting      10
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        wMaxPacketSize     0x1380  3x 896 bytes
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting      11
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        wMaxPacketSize     0x13fc  3x 1020 bytes
        bInterval               1
        UNRECOGNIZED:  08 0b 02 02 01 02 00 00
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        2
      bAlternateSetting       0
      bNumEndpoints           0
      bInterfaceClass         1 Audio
      bInterfaceSubClass      1 Control Device
      iInterface              0
      AudioControl Interface Descriptor:
        bLength                 9
        bDescriptorType        36
        bDescriptorSubtype      1 (HEADER)
        bcdADC               1.00
        wTotalLength           38
        bInCollection           1
        baInterfaceNr( 0)       3
        bLength                12
        bDescriptorType        36
        bDescriptorSubtype      2 (INPUT_TERMINAL)
        bTerminalID             1
        wTerminalType      0x0201 Microphone
        bAssocTerminal          0
        bNrChannels             1
        wChannelConfig     0x0000
        iChannelNames           0
        iTerminal               0
        bLength                 9
        bDescriptorType        36
        bDescriptorSubtype      3 (OUTPUT_TERMINAL)
        bTerminalID             3
        wTerminalType      0x0101 USB Streaming
        bAssocTerminal          0
        bSourceID               5
        iTerminal               0
        bLength                 8
        bDescriptorType        36
        bDescriptorSubtype      6 (FEATURE_UNIT)
        bUnitID                 5
        bSourceID               1
        bControlSize            1
        bmaControls( 0)      0x03
          Mute
          Volume
        iFeature                0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        3
      bAlternateSetting       0
      bNumEndpoints           0
      bInterfaceSubClass      2 Streaming
      iInterface              0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        3
      bAlternateSetting       1
      bNumEndpoints           1
      iInterface              0
        bLength                 9
        bDescriptorType         5
        bEndpointAddress     0x86  EP 6 IN
        bmAttributes            5
          Usage Type               Data
        wMaxPacketSize     0x0000  1x 0 bytes
        bInterval               4
        bRefresh                0
        bSynchAddress           0
        AudioControl Endpoint Descriptor:
          bLength                 7
          bDescriptorType        37
          bDescriptorSubtype      1 (EP_GENERAL)
          bmAttributes         0x01
            Sampling Frequency
          bLockDelayUnits         0 Undefined
          wLockDelay              0 Undefined
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        3
      bAlternateSetting       2
      bNumEndpoints           1
      iInterface              0
        bLength                 9
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        bInterval               4
        bRefresh                0
        bSynchAddress           0
          bLength                 7
          bDescriptorType        37
          bmAttributes         0x01
            Sampling Frequency
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        3
      bAlternateSetting       3
      bNumEndpoints           1
      iInterface              0
      AudioStreaming Interface Descriptor:
        bLength                 7
        bDescriptorType        36
        bDescriptorSubtype      1 (AS_GENERAL)
        bTerminalLink           3
        bDelay                  1 frames
        wFormatTag              1 PCM
        bLength                11
        bDescriptorType        36
        bDescriptorSubtype      2 (FORMAT_TYPE)
        bFormatType             1 (FORMAT_TYPE_I)
        bNrChannels             1
        bSubframeSize           2
        bBitResolution         16
        bSamFreqType            1 Discrete
        tSamFreq[ 0]        16000
        bLength                 9
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        wMaxPacketSize     0x0030  1x 48 bytes
        bInterval               4
        bRefresh                0
        bSynchAddress           0
          bLength                 7
          bDescriptorType        37
          bmAttributes         0x01
            Sampling Frequency
Device Qualifier (for other device speed):
  bLength                10
  bDescriptorType         6
  bcdUSB               2.00
  bDeviceSubClass         2 ?
  bMaxPacketSize0        64
yogev_ezra
Output of mjpg_streamer with 15fps and 640x480 resolution (twice than the one I chose in Zoneminder):
[root@localhost ~]# mjpg_streamer -i "input_uvc.so -d /dev/video0 -f 15 -r 640x480" -o "output_http.so -p 8080 -w ./"
MJPG Streamer Version.: 2.0
 i: Using V4L2 device.: /dev/video0
 i: Desired Resolution: 640 x 480
 i: Frames Per Second.: 15
 i: Format............: MJPEG
 o: www-folder-path...: ./
 o: HTTP TCP port.....: 8080
 o: username:password.: disabled
 o: commands..........: enabled
Output of "top" when mjpg_streamer is running and camera is viewed via Mozilla FireFox 3 (note that mjpg_streamer uses around 3% CPU compared to ZoneMinder with about 70% CPU):
top - 17:10:45 up 9 min,  3 users,  load average: 0.05, 0.49, 0.42
Tasks:  73 total,   1 running,  72 sleeping,   0 stopped,   0 zombie
Cpu(s):  2.7%us,  1.3%sy,  0.0%ni, 90.0%id,  0.3%wa,  4.0%hi,  1.7%si,  0.0%st
Mem:    495124k total,   244484k used,   250640k free,    32476k buffers
Swap:  1048568k total,        0k used,  1048568k free,   146188k cached
 2921 root      17   0 45544 1712 1412 S  2.3  0.3   0:00.44 mjpg_streamer
 2936 root      17   0  6992 2104 1720 S  1.0  0.4   0:00.03 sshd
 2528 root      15   0  2192  984  796 R  0.7  0.2   0:02.89 top
  320 root      10  -5     0    0    0 S  0.3  0.0   0:00.78 kjournald
 2032 mysql     15   0  136m  19m 4512 S  0.3  4.0   0:01.74 mysqld
    1 root      15   0  2064  620  532 S  0.0  0.1   0:01.94 init
    5 root      10  -5     0    0    0 S  0.0  0.0   0:00.00 events/0
    6 root      10  -5     0    0    0 S  0.0  0.0   0:00.01 khelper
   10 root      10  -5     0    0    0 S  0.0  0.0   0:00.01 kblockd/0
   60 root      15  -5     0    0    0 S  0.0  0.0   0:00.05 kseriod
tail -f /var/log/messages when mjpg_streamer is started:
Dec  6 17:06:13 localhost MJPG-streamer [2641]: starting application
Dec  6 17:06:13 localhost MJPG-streamer [2641]: MJPG Streamer Version.: 2.0
Dec  6 17:06:13 localhost MJPG-streamer [2641]: Using V4L2 device.: /dev/video0
Dec  6 17:06:13 localhost MJPG-streamer [2641]: Desired Resolution: 640 x 480
Dec  6 17:06:13 localhost MJPG-streamer [2641]: Frames Per Second.: 15
Dec  6 17:06:13 localhost MJPG-streamer [2641]: Format............: MJPEG
Dec  6 17:06:13 localhost MJPG-streamer [2641]: www-folder-path...: ./
Dec  6 17:06:13 localhost MJPG-streamer [2641]: HTTP TCP port.....: 8080
Dec  6 17:06:13 localhost MJPG-streamer [2641]: username:password.: disabled
Dec  6 17:06:13 localhost MJPG-streamer [2641]: commands..........: enabled
Dec  6 17:06:13 localhost MJPG-streamer [2641]: starting input plugin
Dec  6 17:06:13 localhost MJPG-streamer [2641]: starting output plugin: output_http.so (ID: 00)
Dec  6 17:10:29 localhost MJPG-streamer [2921]: serving client: 10.0.0.10:4563
yogev_ezra
Got another UVC camera, and encountered the same problem:
Bus 001 Device 003: ID 0c45:6310 Microdia
Bus 001 Device 002: ID 18e8:6238 Qcom
[root@localhost tmp]# lsusb -v -d 0c45:6310
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceSubClass         2 ?
  bMaxPacketSize0        64
  idVendor           0x0c45 Microdia
  idProduct          0x6310
  bcdDevice            1.00
  iManufacturer           2 Sonix Technology Co., Ltd.
  iProduct                1 USB 2.0 Camera
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength          569
    bNumInterfaces          2
    iConfiguration          0
    bmAttributes         0x80
    MaxPower               98mA
    UNRECOGNIZED:  08 0b 00 02 0e 03 00 05
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              5 USB Camera
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x83  EP 3 IN
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval               6
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       0
      bNumEndpoints           0
      iInterface              0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       1
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        wMaxPacketSize     0x0080  1x 128 bytes
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       2
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        wMaxPacketSize     0x0100  1x 256 bytes
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       3
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       4
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       5
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        wMaxPacketSize     0x1320  3x 800 bytes
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       6
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        wMaxPacketSize     0x1400  3x 0 bytes
        bInterval               1
  bLength                10
  bDescriptorType         6
  bcdUSB               2.00
  bDeviceSubClass         2 ?
  bMaxPacketSize0        64
general info
    VIDIOC_QUERYCAP
        driver                  : "uvcvideo"
        card                    : └|└|иKхTю/хTю"
        version                 : 0.1.0
standards
inputs
    VIDIOC_ENUMINPUT(0)
        index                   : 0
        type                    : CAMERA
        audioset                : 0
        tuner                   : 0
        std                     : 0x0 []
        status                  : 0x0 []
video capture
        index                   : 0
        flags                   : 0
        fmt.pix.width           : 320
        fmt.pix.bytesperline    : 640
        fmt.pix.sizeimage       : 153600
        fmt.pix.priv            : 0
controls
        type                    : INTEGER
        minimum                 : -64
        maximum                 : 64
        step                    : 1
        default_value           : 0
        flags                   : 0
        type                    : INTEGER
        minimum                 : 0
        maximum                 : 95
        step                    : 1
        default_value           : 0
        flags                   : 0
        type                    : INTEGER
        minimum                 : 0
        maximum                 : 128
        step                    : 1
        default_value           : 65
        flags                   : 0
    VIDIOC_QUERYCTRL(BASE+3)
        type                    : INTEGER
        minimum                 : -40
        maximum                 : 40
        step                    : 1
        default_value           : 6
        flags                   : 0
general info
    VIDIOCGCAP
        channels                : 1
        audios                  : 0
        maxwidth                : 0
        maxheight               : 0
        minwidth                : 48
        minheight               : 32
channels
tuner
audio
    VIDIOCGPICT
        brightness              : 32768
        hue                     : 37683
        colour                  : 33279
        contrast                : 0
        whiteness               : 4287
        depth                   : 16
        palette                 : YUYV
buffer
window
    VIDIOCGWIN
        x                       : 0
        y                       : 0
        width                   : 320
        height                  : 240
        chromakey               : 0
        flags                   : 0
Again, mjpg_streamer works fine (although this camera only supports YUV so I had to use -y prefix):
[root@localhost tmp]# mjpg_streamer -i "input_uvc.so -d /dev/video0 -f 15 -r 640x480 -y" -o "output_http.so -p 8080 -w ./"
 i: Format............: YUV
 i: JPEG Quality......: 80
ris2t
Logitech Sphere AF Palette
Post by ris2t »
Any solution to this palette problem.
I've just installed Zoneminder 1.24 on Intrepid 8.10 and encountered the same thing with my Logitech Sphere AF.
foxtroop11
Post by foxtroop11 »
yogev_ezra,
I was the person that setup Openwrt on my Linksys NSLU2. I used a special build of Openwrt that starts up two mjpg_steamer sessions if it detects two webcam's plugged in. I've had this running for weeks now with no issues. I then plugged in a Orbit Sphere and contacted the person that initally got the Orbit working. He then helped me gain control of the tilt/pan/ and reset through a new module he made for Zoneminder. It works great and the openwrt device has no issues's supporting the load at all.
I'm also working on dd-wrt routers, but since I can't get any help in the forums I'm thinking about reverting to openwrt on the routers as well and dealing with the loss of Wireless in the 2.6 kernel of openwrt and broadcom.
