Could anybody help with ideas? Should I blame the webcam or the mjpg_streamer?
I am testing E3500 (id 046d:09a4) on Debian Etch, which is updated to test and unstable. The camera itself is recognized well:
Nov 21 01:01:11 cam kernel: [ 113.750005] usb 2-2.2: new full speed USB device using uhci_hcd and address 3
Nov 21 01:01:12 cam kernel: [ 113.976940] usb 2-2.2: configuration #1 chosen from 1 choice
Nov 21 01:01:12 cam kernel: [ 113.982660] usb 2-2.2: New USB device found, idVendor=046d, idProduct=09a4
Nov 21 01:01:12 cam kernel: [ 113.982770] usb 2-2.2: New USB device strings: Mfr=0, Product=0, SerialNumber=2
Nov 21 01:01:12 cam kernel: [ 113.982857] usb 2-2.2: SerialNumber: 0BB31220
Nov 21 01:01:12 cam kernel: [ 114.720852] Linux video capture interface: v2.00
Nov 21 01:01:12 cam kernel: [ 114.896233] uvcvideo: Found UVC 1.00 device <unnamed> (046d:09a4)
Nov 21 01:01:12 cam kernel: [ 114.912015] input: UVC Camera (046d:09a4) as /class/input/input5
Nov 21 01:01:12 cam kernel: [ 114.912015] usbcore: registered new interface driver snd-usb-audio
Nov 21 01:01:12 cam kernel: [ 114.917611] usbcore: registered new interface driver uvcvideo
Nov 21 01:01:12 cam kernel: [ 114.917721] USB Video Class driver (v0.1.0)
cam:~# mjpg_streamer -i "input_uvc.so -r 320x240 -y -f 1 -d /dev/video0" -o "output_http.so -p 8080"
MJPG Streamer Version.: 2.0
i: Using V4L2 device.: /dev/video0
i: Desired Resolution: 320 x 240
i: Frames Per Second.: 1
i: Format............: YUV
i: JPEG Quality......: 80
format asked unavailable get width 176 height 144
o: www-folder-path...: disabled
o: HTTP TCP port.....: 8080
o: username:password.: disabled
o: commands..........: enabled
Nov 21 01:27:16 cam MJPG-streamer [3128]: starting application
Nov 21 01:27:16 cam MJPG-streamer [3128]: enabling daemon mode
Nov 21 01:27:16 cam MJPG-streamer [3130]: MJPG Streamer Version.: 2.0
Nov 21 01:27:16 cam MJPG-streamer [3130]: Using V4L2 device.: /dev/video0
Nov 21 01:27:16 cam MJPG-streamer [3130]: Desired Resolution: 320 x 240
Nov 21 01:27:16 cam MJPG-streamer [3130]: Frames Per Second.: 6
Nov 21 01:27:16 cam MJPG-streamer [3130]: Format............: MJPEG
Nov 21 01:27:16 cam MJPG-streamer [3130]: www-folder-path...: disabled
Nov 21 01:27:16 cam MJPG-streamer [3130]: HTTP TCP port.....: 8080
Nov 21 01:27:16 cam MJPG-streamer [3130]: username:password.: disabled
Nov 21 01:27:16 cam MJPG-streamer [3130]: commands..........: enabled
Nov 21 01:27:16 cam MJPG-streamer [3130]: starting input plugin
Nov 21 01:27:16 cam MJPG-streamer [3130]: starting output plugin: output_http.so (ID: 00)
Nov 21 01:27:25 cam MJPG-streamer [3130]: serving client: 127.0.0.1:43976
Nov 21 01:27:52 cam MJPG-streamer [3130]: serving client: 127.0.0.1:43977
Nov 21 01:28:11 cam MJPG-streamer [3130]: serving client: 127.0.0.1:43978
wget http://localhost:8080/?action=stream
Here is the result:
--2008-11-21 01:29:00-- http://localhost:8080/?action=stream
Resolving localhost... 127.0.0.1
Connecting to localhost|127.0.0.1|:8080... connected.
HTTP request sent, awaiting response... 200 OK
Length: unspecified [multipart/x-mixed-replace]
Saving to: `index.html?action=stream.1'
[ <=> ] 22 --.-K/s
Can anybody hint me where to seek for the solution?! Could E3500 have some controversial or undocumented format that mjpg_streamer is unable to receive?
Disclaimer: honestly saying, why I am writing such a long problem description here is because Google seems to index zoneminder articles extremely well
